TC problem in evo 9 6 speed
Old May 8, 2008 | 02:19 AM
I'm blue's Avatar
Originally Posted by Jersey Dino
Gotcha I'm Blue. I wasn not sure what the case was since you didnt say whether the car was modded or not. I am not 100% sure but I have read threads about swapping the 6 speed MR transmission out for the 5 speed. I think CBRD did it for a customer as a mutual swap. So you may want to either contact them or search around here if that is in deed your question "will the 5speed bolt up in place of the MR 6 SPeed?" You can also check out TRE for a transmission build, but again, I am not sure if they do the 6 speed of just the 5 speed as well. good luck and let us know what happens.
Thanks a lot for ur great help just to keep u posted i did end up ordering the shep Tc and its here now it will be on the car soon and that should set things right, about the car being modded yes it is with some small bolt ons
Old May 8, 2008 | 02:20 AM
I'm blue's Avatar
Originally Posted by CBRD
hey guys,
TC fits either if its ACD.... no problem..
the only "tricky" part of the swap is this... the 6 speed and 5 speed harnesses ON the trans. they need to be cut and soldered, or just buy new ones from the dealer.
then you need the mounting plate for the shift cables that bolt to the tranny, and the box inside of the car, and the cover for the center console.. and a a metal bracket that holds the console up.
thats it, otherwise, its not difficult at all!!
cheers
cb
Thank you for such a very useful information
Old May 8, 2008 | 04:58 AM
CBRD's Avatar
no problem, if you have questions feel free to call us..
717 751 2345 ext 101
cb
SLVRNBLK
29
Aug 6, 2018 08:59 AM
TronCarterIII
Nov 25, 2016 08:05 PM
SRT4 to Evox
Sep 8, 2012 12:53 PM
Gumby56
May 5, 2009 06:55 PM
I'm blue
24
May 8, 2008 02:53 AM
