Apexi filter and induction box questions
Old Feb 6, 2008 | 08:50 PM
AZ-IX's Avatar
I had the Blitz induction cover and it worked perfectly
Old Feb 6, 2008 | 09:42 PM
voidhawk's Avatar
Originally Posted by razorlab
The Apexi filter with adapter does indeed mess with the MAF readings much more than other units I have found. The direct bolt on without any adapter BR or BR style filter is a much better way to go.
You can also great creative with the stock airbox and mount the filter in it for stealth and cooler air:
this is slick - nice setup. I wonder if you actually get more airflow though? Is the filter element on the stock box the bottle neck and you get better airflow because of the increased surface area on the cone filter? Just from looking at it, it seems the filter surface area is actually not all that different. Hard to gauge of the one photo though ...
Old Feb 7, 2008 | 06:09 AM
l2r99gst's Avatar
I asked the same thing. He actually has the whole bottom of the stock airbox cut out. So, it's basically just the top of the airbox covering the cone filter. I agree, it's a very nice stock appearing setup, without the need to build your own heat shield.
ilikeboost
Mar 12, 2011 04:58 PM
buddylk
Mar 17, 2009 06:06 PM
SIKEVO9
12
Jul 17, 2008 06:54 AM
Ragnarok
Jul 3, 2006 06:20 PM
TURBODAWG
May 25, 2005 05:11 PM
