Backfiring Problem
Old Jan 14, 2008 | 05:36 PM
BlueEvolution's Avatar
Backfiring Problem
I have an 05 Evo 8 and i have a backfiring problem. I have a HKS SSQV blow off valve, which is recirculated to fix the backfiring but it didnt do anything. I also have some small basic mods, and i am running on a factory tune. It usually starts backfiring around 4700rpm. Anyone have any ideas wat it can be?
Old Jan 14, 2008 | 05:37 PM
wrceuro's Avatar
boost leak. Check for boost leaks. Changin the spark plugs might help.
Old Jan 14, 2008 | 05:40 PM
bluebyu36's Avatar
throw that blow off valve out,clean your mass air,and check your plugs!
Old Jan 14, 2008 | 06:06 PM
mudduck's Avatar
if any of those "small, basic mods" you have is an intake or exhaust, you probably just need a retune
Old Jan 14, 2008 | 09:01 PM
06ravenmr's Avatar
i had the exact same problem as u are having. brought it to the dealer and found out it was a clogged cat.change the plugs as well.
Old Jan 14, 2008 | 11:37 PM
fatcircles's Avatar
I would still get rid of the aftermarket BOV and put your stock one back on so your car will run better.
Dbzguy
Jul 10, 2012 05:19 AM
andrewr
Sep 18, 2010 09:13 AM
racer135
Nov 5, 2009 07:18 AM
kmartizdatruth
Aug 17, 2009 08:11 PM
GOTMEALANCER
Lancer Troubleshooting
Jul 4, 2006 04:58 AM
