4th gear problem
Old Jan 15, 2008 | 10:39 AM
gen3eclipsegt's Avatar
Question 4th gear problem
ever since i got the car i have had problems getttin into 4th in high rpms anything past 5500 really hard to get it like ther is no gear there anything lower than that its fine to get in gear???
Old Jan 15, 2008 | 06:54 PM
choko's Avatar
boost leak. get it tested..fixed, and u good to go
Old Jan 16, 2008 | 10:32 AM
EVIL_EVO_VIII's Avatar
wth does a boost leak have anything to do with getting locked out of gear? You sure are a noob...
gen3eclipsegt i have the same problem.. You try adjusting your clutch pedal? try that to see if it helps. How many miles on the clutch?
Old Jan 16, 2008 | 11:06 AM
quick silver 8's Avatar
Lol ^^^^^
Old Jan 16, 2008 | 11:17 AM
bboy_RES's Avatar
i have the same problem as well, but it's 5th gear that i get locked out. occassionally i'll be able to shift into it with no problems, but most of the time i get locked out. i have about 10k miles on the stock clutch. should i try adjusting the clutch pedal?
Old Jan 16, 2008 | 12:00 PM
klutchcontrol's Avatar
Registered User
WTF??? And I thought I was a noob...LOL
Old Jan 16, 2008 | 12:02 PM
dsmjeffro's Avatar
try to bleed your clutch & adj the clutch pedal so it lets go a little higher make sure there is still freep0lay though if not its prolly time for a new clutch
my stocker had lockout issues when it got hot & so do many many act`s
Old Jan 16, 2008 | 12:37 PM
sound good that sounds true if ya think about it .... thanks for your help but locking out of 4th really messes up your time .... last time at the track i ran a 12.8 at 119 mph at 18psi and locked out of 4th i got into 4th right before i crossed the line so im hoping for low 12's with working boost and no lock out
Old Jan 16, 2008 | 12:41 PM
dsmjeffro's Avatar
119 mph i went 12.1 @ 113! your going 11`s with that mph
Old Jan 16, 2008 | 12:43 PM
eponti's Avatar
Nah i bet you its the tire pressure.
Old Jan 16, 2008 | 12:49 PM
dsmjeffro's Avatar
i think you are right !
Old Jan 16, 2008 | 12:57 PM
evo noob's Avatar
actually whats really going on is that the trans that is in the evo 8 is from an evo 7 and Mitsubishi didnt beef it up any and theres a TSB (technical service bulletin) on this problem and the correction for it is to replace the synchronizers inside the trans with performance synchronizers. there should be no need of adjusting the clutch pedal is a hydrolic clutch and is self adjusting until you replace the clutch
Old Jan 16, 2008 | 01:18 PM
well the clutch isint stock neither is the flywheel so the only real way around that problem is to switch out the syncros upgraded ones or one from a evo9 tranny??? it is a really heavy clutch if i were to change the clutch to something diffrent would that maybe correct the problem .... and if i hit even a 11.9 i would be very happy
Old Jan 16, 2008 | 01:25 PM
I have a IX and im having lockout issues at 7k in 4th most of the times. I have to let the rpms drop real quick and then shift 25k+ miles stock clutch, 2 11sec passes
Old Jan 16, 2008 | 01:45 PM
04AWDTURBOEVO's Avatar
119 mph on the Stock Turbo at 18 psi is not possible. May be on Science Fiction Movies, .
Or, a good Shot of NOS, .
If you went "into 4th right before you crossed the line" like you sayed, then I make the conclution that you were not using NOS, nor going 119 mph, .
Come on, some of Us been there and done that.
