Stock turbo - how much boost???
Old Jan 16, 2008 | 02:37 PM
V.8MR's Avatar
crank that bish up crazy.
Old Jan 16, 2008 | 02:39 PM
mplspilot's Avatar
fas-n-furyus? Rly?
Old Jan 16, 2008 | 02:44 PM
evo8fl's Avatar
Originally Posted by 04AWDTURBOEVO
Going from an AVC-R, back to a Manual Boost Controllers, is like going back to the Stone Age.
AVC-R is one of the Greatest Boost Controllers ever made, .
I use the Greddy E-01. Similar Gizmo, newer Technology.
listen to him he knows a little bit bout evos, stock internals i see ppl running 28, 30, 32psi with meth make sure u get tuned first with someone who knows what he's doing
Old Jan 16, 2008 | 02:58 PM
V.8MR's Avatar
no tune required. The stock motor can take more than the turbo can put out. Just crank that bish up mang. DOnt worrRy
Old Jan 16, 2008 | 02:59 PM
V.8MR's Avatar
Yah, crank it up.
Old Jan 16, 2008 | 03:00 PM
lemmonhead's Avatar
compressor map to me says you should run 25psi tops. Thats my 2 cents.
Old Jan 16, 2008 | 03:06 PM
4WS Tuning's Avatar
The amount of boost depends on your mods, how aggresive you want the car and whos tuning it.
Anywhere from 20-25 pounds on pump gas can be run.
Shoot me a PM if you'd like to discuss your specific car in detail.
Cheers!
Old Jan 16, 2008 | 03:07 PM
fas-n-furyus's Avatar
do i need to change the head stud bolts to ARP?
dont want them to stretch and blow the head off....lol
will the rod and the rod bolts hold also?
Old Jan 16, 2008 | 04:28 PM
90GSX-03EVO's Avatar
Just take off your O2 housing and weld the wastegate flapper door shut.
Old Jan 16, 2008 | 06:00 PM
BURNALL_4's Avatar
There's to much crap to go worng with electronics....the good ol' MBC is where its at.
Old Jan 16, 2008 | 06:04 PM
housedj's Avatar
i modded the wastegate & got my stock VIII turbo to spike 37PSI once. i haven't spiked that high since but i do run 30PSI on Sunoco 110 leaded...
Old Jan 16, 2008 | 06:10 PM
blackdemon's Avatar
At 30psi our stock turbos are not so efficient .
Old Jan 16, 2008 | 06:30 PM
APEX1's Avatar
Originally Posted by fas-n-furyus
Hey guys,
i drive a evo9 and was wonder whats the maximum boost the stock turbo can manage and what power will i end up with? Currently running upgraded IC, 3" exhaust and methanol injection (just installed-no tuning yet).
Was considering to upgrade to a 20G or Evogreen.... What are the expected hp gains over the stock turbo?
Im on a stock IX turbo. The boost tho it depends on what gear your in. Its 28 psi and higher but, in 5th gear it spikes to 33 psi. Mods are in the sig.
Old Jan 16, 2008 | 06:40 PM
Tarmacisback69's Avatar
Ive heard stock ix turbo's can spike at peak of 36 psi and taper back down with a forge wastegate to 23 psi.
Old Jan 16, 2008 | 08:06 PM
04AWDTURBOEVO's Avatar
I know what you mean, but it is the 21st Century.
Today it is all about Electronics .
That is why FWD cars are going 7's at over 180 mph and RWD Imports going sub 6.5 1/4 mile times at over 220 mph.
This was not possible, even in the 90's.
Not much goes wrong with Electronics. The majority of the problem is that consumer X buys it, and never understands how they work. They either never learn how to use them, or don't try, and give up.
Manual Boost controllers are good. They do the work, and they are much less money. But, to trash an AVC-R for one, is, well, you know what I mean, .
