Is there a power difference between a 4 bolt vs 5 bolt hotside?
Old Jan 16, 2008 | 05:58 PM
2theMAX's Avatar
Take these two pictures for example. Let's say everything is equal between two turbos except for the hotside. Does the 5 bolt housing on a turbo such as the GT35R make less power with an internal wastegate than a 4 bolt without the internal wastegate? I am wondering if I should switch up my kit. I am going to be upgrading to a T67/37R. I want maximum hp and want to do this the right way. Thanks.
Comparison Pics:
5 bolt w/ wastegate
4 bolt w/out wastegate
Old Jan 16, 2008 | 10:06 PM
riceball777's Avatar
4 bolt housing are known to make a very littler more power
5 bolt housings have the internal wastegate option
Old Jan 17, 2008 | 08:58 AM
BURNALL_4's Avatar
Anyone that wants to make good power goes external WG.
Old Jan 17, 2008 | 02:03 PM
2theMAX's Avatar
There will be alot involved for me to have my manifold modified and alot of extra expense in getting the 4 bolt hotside to work. If I can make quite a bit more power this way, then it might be worth it. I just wish I new how much of a difference there would be.
Old Jan 17, 2008 | 02:15 PM
EvoDan2004's Avatar
hate to go off topic. but what turbo is that?? looks like a 3582. if so can u take a pic on the compressor side. i want to see your compressor cover. thanks bro
Old Jan 17, 2008 | 02:45 PM
2theMAX's Avatar
Which one? They are both Garrett/Precision turbos. Ones is a gt35r the other is a pt67/37r.
Old Jan 17, 2008 | 03:56 PM
steadly2004's Avatar
many 5 bolts are 2.5" outlet, where as many 4 bolts are 3" outlet. (not all of course)
Old Jan 17, 2008 | 05:18 PM
EvoDan2004's Avatar
hum. if you dont mind both of them. if i had to pick one though i pick the 5 bolt one. thanks bro.
Old Jan 17, 2008 | 05:55 PM
Spaceball 1's Avatar
I have heard there are people that have picked up about 40whp going from the 5 bolt to the 4 bolt, but i believe this is at like 30+ psi.
Old Jan 17, 2008 | 06:08 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I doubt the 5 bolt makes less power since both AMS and Buschur run 5 bolts.
Old Jan 17, 2008 | 07:01 PM
MRJEVO's Avatar
I did see that Buschur's kits DO NOT have the internal wastegate on the turbo though. That is a big difference also.
Old Jan 17, 2008 | 07:08 PM
The OP can run a wastegate off the O2 housing like AMS does with their setup. They claim it makes the most power while offering great boost control and I don't doubt them based on their successes.
Old Jan 17, 2008 | 07:14 PM
2theMAX's Avatar
As requested, this is the front of the GT35R
The PT67/37R
Old Jan 17, 2008 | 09:35 PM
sparky's Avatar
Not one to argue with success, however, I am having a tough time comprehending the effectiveness of your postulated, post-turbine housing wastegate location. But, of course my conceptual powers are probably hobbled by the fact that I am thinking in terms of a stock-like turbo setup as well as the effects of this drat 7.9% brew.
Old Jan 17, 2008 | 09:45 PM
boostin06ggevo's Avatar
5 bolts you mostly run 38mm wastegates and 4 bolt is a newer design hotside that weighs a little less and mostly 44 mm wastegates are ran. The t3 5bolt design was used on older vw's turbo diesel....
