ix cams po11 code
I am sure ttp would give you a break on fixing it for you. Take up scott on his offer. Stop what you're doing, talk with scott and get your car back on the road... For the love of all that is evo... Do it.
we finished the tune about a month ago to the day
https://www.evolutionm.net/forums/sh...d.php?t=326925
oops, I'm getting PM's for the fix.
I don't know exactly what Troy ended up doing but I think he replaced some pieces around the cam.
the problem was NOT the tune.
Bumping this topic back from the dead... I am having the same problem with my Evo 9 with the P0011. What was the solution to this problem, and what did you have to replace around the camshaft? Did you just replace the sensor? Thanks for your help.
good point but unless he changed my mivec map that shouldn't be the issue. It's within spec and nobody else is having a problem with the same map. I'm not sure why he's no longer responding to this thread if he found the fix...kind of odd.
I've seen tuners put 30-33* MIVEC advance in Evo IX maps that the ECU does not understand and will throw P0011.
In the past the maximum MIVEC advance was not well known but these days there should be no reason for seeing it in any map.
So who has got the answer? I am in the exact same boat as evoboi, after done the cam install numerous times and checking timing, the sensor is not 180 out, everything is ok, car runs great but I get that code.
come on guys, share to the community.
