Question With Turbos
Old Jan 23, 2008 | 04:40 PM
PeteTheHeat's Avatar
Ok.. Do u have any suggestions on what kind of Turbo??
Old Jan 23, 2008 | 05:43 PM
Johnboy1065's Avatar
maybe the evo green turbo. BUT I'm not exactly sure how much hp you can get with it on 93 octane. you should try searching for it.
Old Jan 23, 2008 | 06:23 PM
XIEvolutionIX's Avatar
your not gonna be able to get 430whp on 2000$ unless your gonna buy used parts or something, the green itself is close to 1700$ with out an install or tune, and im pretty sure you have to have an evo9 turbo to do buschur's green conversion which runs at 900$ i think, and you probably still wont be able to hit 430whp on straight pump gas. look into saving some more money and get a gt30r with all the supporting mods you can afford, and you should be able to get 430whp relatively easily with out meth on a good tune. you could hit 400whp with the green though, and it would be a much cheaper route if you dont mind sacrificing some horses. doing alot of research can help too.
Old Jan 23, 2008 | 07:48 PM
Ok... Well 400hp is good.. I'll take a look at the Evo Green Turbo... With this Evo Green Turbo would I just have to switch out of the new one with the old one and won't have to modify anything??
Old Jan 23, 2008 | 08:05 PM
czevo's Avatar
You also need a fuel pump injectors def a good tune you should also get cams to reach your goal of 400+ whp on pump gas
Old Jan 23, 2008 | 08:20 PM
9sec9's Avatar
To get 400whp, you would need to upgrade the injectors. As far as ease of installation, it's a no brainer change out. At this point, the Evo Green has been tuned several times by many tuners. The boost levels are fairly well known so a lot of information has already been gathered on the Forced Performance Green. You won't regret making the swap. Spoolup is nearly identical to stock. If you want more performance, just get a race tune also and raise the boost on the weekends. Lower it back for the street and reload your street tune. It's not as difficult as it sounds. If you raise the boost for the weekends, just remember to get the fuel to go with it.
Old Jan 23, 2008 | 09:02 PM
Sofa King Fresh's Avatar
Hta35r Ftw!!!!!!!!!!!!!!!!
jk_evo8
May 8, 2016 03:50 PM
darkblues24
Mar 30, 2016 07:11 AM
batty200
Jul 12, 2012 03:11 PM
TaKTikZ
Lancer Aftermarket Forced Induction Tech
17
Nov 27, 2010 09:55 AM
