EvoM & Ebay = 500WHP for less than $4000 with built engine!
Old Jan 25, 2008 | 05:40 PM
  #31
boostedwrx's Avatar
Get some motor mounts now
Old Jan 26, 2008 | 01:07 PM
  #32
Redline06's Avatar
About the ugliest engine bay.. I've seen.. lol but nice numbers.. despite what you spent..! You just proved that you hold a nice power to dollar ratio that's all.. nothing to show claim about.. but whatever makes people happy.. right??
Old Jan 26, 2008 | 05:44 PM
  #33
EvoTech's Avatar
I guess spending big money on JDM bling makes guys like you happy. Whatever your into. I am into power, drivability and a car that can do it all well. I am proud of putting together a 500 hp evo for chump change and a lot of hard labor. Others are proud to break out their parents Platinum Visa card and show off titanium bling mods that cost more than my whole build. Different strokes for different folks, I guess. I do feel that I have something here to "show claim" about. I did all the work myself including building the engine and fabricating all the pieces for the turbo kit. I am not a mechanic nor do I have a platinum Visa card. So to achieve this as a DIY'r on a budget gives me a sense of accomplishment. I never bragged about my engine bay. I guy on here asked for pics and I provided them. Period. I just don't get this kind of negativity. I guess I will have to learn to accept it if I continue to be active on this board since it seem all to common.
They are already there along with whiteline bushings all around.
Old Jan 26, 2008 | 05:54 PM
  #34
TopLevelPerformance's Avatar
Great job on the beast Ed, your hard work has paid off. This car has show and enough go to take care of business Cant wait till the track opens up to see what she does, sick daily driver.
Old Jan 26, 2008 | 07:43 PM
  #35
hokiruu's Avatar
WOW. Nice power to dollar ratio IS something to "show claim" about. I guess you think we should all like an respect your car more than his because you spent more and have less power than him, but hey, supposedly your engine bay is better looking. You get absolutely no respect from me...
Old Jan 26, 2008 | 07:52 PM
  #36
waynea's Avatar
yeah, good work. The Evo was made to be fast and inexpensive and you taken that to the next level. Anyone can add all the pretty bits they want, but all I ever wanted out of mine was fast, low cost and invisible.
Old Jan 26, 2008 | 07:59 PM
  #37
EVOlution561's Avatar
Ver nice build man, congrats. I have a similiar goal in mind.
Old Jan 26, 2008 | 08:13 PM
  #38
20Grockit's Avatar
awesome setup for the $$$
Old Jan 27, 2008 | 03:59 AM
  #39
EvoTech's Avatar
Thanks for the support guys. I agree. Braging about off the shelf JDM parts that you bolted up is lame. Not that there is anything wrong with nice looking parts, but all it shows is that you are not afraid to spend money. Getting your hands dirty and doing something unique is what gets my respect. I wear a suit and tie to work everyday yet my hands look like those of a diesel mechanic. Cuts, grease under my nails. and a lot of burns and bruises prove that all my free time has been spent learning how to tig weld, fabricate ,and generally bring the evo to where it is today. I have no problem saying that I am proud of that.
Old Jan 27, 2008 | 10:35 AM
  #40
kaonashi's Avatar
I just pre fit my parts today and the manifold/downpipe fit flawless without any extreme mod except smoothing out the holes and loose metal flakes and welding left around. I'll have my on the road probably 1-2 weeks and have some track times on a simular set up just not as extreme.
Old Jan 27, 2008 | 10:47 AM
  #41
20Grockit's Avatar
well keep us updated on the performance at the track man. anxiously awaiting some times
Old Jan 27, 2008 | 12:42 PM
  #42
kaonashi's Avatar
Does my setup look like crap lol? i spent less then he did .....
Old Jan 27, 2008 | 03:27 PM
  #43
EvoTech's Avatar
If you have the same manifold, be careful about the WG flange. Although it looks like a tial will bolt up to it, it will not tighten down correctly and it will leak. I found out the hard way as have others. Best bet is to cut it off and weld on a tial flange. If you are runnning the cheapo SS chrome WG, then it will mate fine. You may also want to weld a brace to the WG flange and bolt it to the block. This is where they known to crack. We have done a lot of testing on these and found the weak points. FWIW we have a shop car that went 9.8 @ 143 MPH with this manifold so it is definitly able to handle the power.Were you able to bolt the DP to the turbo with no problems. That would surprise me. How about the clearence to the oil pan. I found that to be a problem as well.
Old Jan 27, 2008 | 04:35 PM
  #44
kaonashi's Avatar
it bolted to the turbo fine. BUT i did have issue's with the a/c line i had to tap it with a rubber mallet to move it some so it would fit without rubbing. As far as the WG i am cutting it off tomorrow and welding my 38mm wastegate flange on it since i had a dumptube for a 38mm and it was cheaper . I just see an problem of where to angle the wastegate. for radiator/ ac clearance.
Old Jan 27, 2008 | 05:07 PM
  #45
kaonashi's Avatar
That and i cant get the front O2 sensor to reach the bung.
