threw 2 codes after cam install (rich idle)
Old Jan 25, 2008 | 12:55 AM
Dapper Dan's Avatar
ok i swapped out my bc 272 cams for some comp 280s, i also threw on some arp head studs(the one by one method)
ive installed tons of cams and head studs and have never had this problem.
im getting a super rich idle and
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0108: Barometric Pressure Circuit High Input
when my ignition is on and my car is off i clear the codes and they come right back, i checked all my connections and everything is good.
my timing is perfect and my cas is on the right way.
i know its probably something stupid i looked over but its 3am and i cant thinlk straight.. any ideas?
Old Jan 25, 2008 | 01:11 AM
Jameson_IXMR's Avatar
Silly Q. is your MAF unplugged?
Old Jan 25, 2008 | 01:24 AM
steexz's Avatar
i threw those same codes... and i did a cam install as well as mbc, o2 housing and boost gauge... just reset them and it was fine.
Old Jan 25, 2008 | 02:08 AM
Dapper Dan's Avatar
nvm i found the problem. had nothing to do with my install... damn sensor just decided to take a crap at the same time.....
Old Jan 25, 2008 | 05:39 AM
kaonashi's Avatar
which sensor? i have the barometric preasure high input aswell.
Old Jan 25, 2008 | 08:56 AM
C6C6CH3vo's Avatar
Maf?
Nic Money
Mar 22, 2012 12:20 AM
Y.O.EVO8
Mar 30, 2010 03:40 PM
Nesiop
Aug 12, 2009 09:38 AM
BadazzCR
Aug 23, 2008 07:40 AM
Jersey Dino
11
Dec 10, 2006 08:54 AM
