clutch prob. please help
Old Jan 27, 2008 | 02:07 PM
Mike.p's Avatar
when the car is started it is locked out of every gear....you start the car in 1st it takes off....so i was looking at the slave cyl. and i was not able to push the rod in at all ( witch you should be) so i changed slaves and the same thing..what do you think it could be?? an act clutch was put in about 1500 miles ago but it did this outa the blue..no probs before then.... please help
Old Jan 27, 2008 | 02:43 PM
cfdfireman1's Avatar
Did you bleed the system properly?
Old Jan 27, 2008 | 05:51 PM
Mike.p's Avatar
yeah i sure did.... when i look through the peep hole on the tranny and look at the tob when someone is pushing in the clutch it seems like it is working properly...... im stumped...HELP PLEASE
Old Jan 27, 2008 | 07:33 PM
Mike.p's Avatar
bump!!!
Old Jan 27, 2008 | 09:03 PM
Mike.p's Avatar
Bumppppp
Old Jan 27, 2008 | 09:11 PM
KevinD's Avatar
i'm confused, so is the clutch pedal stuck? or does the clutch pedal move? if it moves, try adjusting the clutch engagement off the floor with the adjustment on the pedal. if you can adjust it off the floor some you should be able to fully disengage the clutch and get it in gear.
Old Jan 27, 2008 | 09:49 PM
Mike.p's Avatar
it moves like it should...we adjusted it almost to the top and still nothing....and the tob is still connected to the pressure plate....so when you push the clutch in you can see the pressure plate pull out..but i guess not far enough
Old Jan 28, 2008 | 08:25 AM
Weird, does the clutch disengage at all or it just totally engaged all the time?
Old Jan 28, 2008 | 04:02 PM
Mike.p's Avatar
the clutch does not disengage.....please help.......im stumped
Old Jan 28, 2008 | 07:08 PM
Mike.p's Avatar
bump
Old Jan 28, 2008 | 07:21 PM
barneyb's Avatar
It could be the friction material has come off the disc and is wedged between the disc and the pressure plate. This happens occasionally.
Old Jan 28, 2008 | 07:40 PM
Evoryder's Avatar
another problem...have you been doing some crazy driving lately ...nice launches? Master cylinder may have crapped out. I'm having near identical issues...
Old Jan 28, 2008 | 09:57 PM
Mike.p's Avatar
the clutch has been installed fpr 1500 miles and was driven easily... when the clutch pedle is presses it seems like it is pulling the pressure plate out like it should be.....but usually you can push the rod that is on the slave in by hand and you cant on this one...would that cause the clutch not to disengage even though it pushs the shift fork towards the pass side like it should?
Old Jan 28, 2008 | 10:10 PM
04AWDTURBOEVO's Avatar
Try adjusting the Clutch.
Give it a turn or turn and 1/2 counter clock wise on the adjustment rod. See what happens.
If no go, then turn it back clockwise 2 1/2 full turns.
I hope that works. Usually does.
If not, look into the bearing itself. The Clutch release Bearing. Could have come loose or it is getting loose. or it could have been bad.
Good luck.
Old Jan 29, 2008 | 04:29 AM
Evoryder's Avatar
air in the system or your master cylinder has gone bad.
