EGR Question
Old Jan 27, 2008 | 08:17 PM
laakness's Avatar
EGR Question
I have been throwing a EGR insufficient flow code and have then been clearing it every couple weeks. I was able to pick up a low milage valve from a local owner.
I'm wondering if it's actually worth throwing on since I now disabled the EGR check in the ECU. I don't have to worry about emissions testing.
Will my gas mileage be affected by the current valve even though the ECU is not checking it? It's hard to see any gas mileage change now since it is winter and the mileage sucks anyway.
Any input would be greatly appreciated.
Old Jan 28, 2008 | 08:21 AM
laakness's Avatar
No educated guesses? I know quite a few people run the egr remove plate.
Old Jan 28, 2008 | 08:28 AM
DTM's Avatar
DTM
Have you checked that both ports on the original EGR valve have not been unplugged or popped off?
Old Jan 28, 2008 | 08:33 AM
deadbeatrec's Avatar
there are 2 hoses that connect to this EGR valve. make sure both are connect to the nipples on the valve itself. the come off due to high boost and its very common. mine came off and i just put it back on. its really hard to see so u basicly just have to feel around for it.
Old Jan 28, 2008 | 08:53 AM
9sec9's Avatar
Be careful when replacing the hose on the nipple. It breaks very easily. Small diameter nipples and close together.
Old Jan 28, 2008 | 09:21 AM
laakness's Avatar
Yeah, the hoses are on. I have 65K on the car.
fostytou
359
Oct 23, 2025 09:54 AM
Beluga
Lancer Engine Tech
Nov 1, 2012 08:06 AM
Mcgee
Oct 11, 2012 04:50 AM
fostytou
Oct 18, 2009 08:53 PM
phabaznbro
Apr 18, 2008 07:44 PM
