View Poll Results: Should I remove the clutch restrictor?
Remove it
80
85.11%
Keep it in
14
14.89%
Voters: 94. You may not vote on this poll
Considering removing clutch restrictor
Old Jan 28, 2008 | 03:27 PM
  #31
KeithD's Avatar
I did not even know anything about this until I found this. Thank you for the great info. I am going to remove mine this weekend. I have a centerforce stage 3 clutch and I thought it was strange that know matter how fast I would let the clutch out it still chattered. I think this is why, the car must be slipping the clutch. I know I'm not. Thanks for the info.
Old Jan 28, 2008 | 03:36 PM
  #32
MR Turco's Avatar
Yeah the stock clutch chatters really bad in the cold, i have a feeling this attributes to it. I am pretty sure i am taking it out.
Old Jan 28, 2008 | 03:49 PM
  #33
mr.romero's Avatar
If anyone is doing this, they should take pics and do a write up.
Old Jan 28, 2008 | 03:54 PM
  #34
Kracka's Avatar
http://evomoto.com/tech_info.php?tPa...5c77616b84523f
Old Jan 28, 2008 | 04:01 PM
  #35
1slowevo's Avatar
Originally Posted by gear head
get rid of it for positive clutch engagement you wont regret it & while your at it install a braided clutch line.
+1
Turco I said the same thing at the last meet. Clutch line is a great add on after pill removal
Old Jan 28, 2008 | 04:53 PM
  #36
MR Turco's Avatar
I have a feeling i might skip the braided line install.
Old Jan 28, 2008 | 04:55 PM
  #37
1slowevo's Avatar
Old Jan 28, 2008 | 05:01 PM
  #38
90GSX-03EVO's Avatar
People have been doing this for a little over a decade now...
Read the first paragraph on this page:
http://www.jumptronix.com/2g_go_fast...emoval_faq.htm
Old Jan 28, 2008 | 05:08 PM
  #39
MR Turco's Avatar
Yeah i have heard of this on the older gens there is just not much info on the evos.
Old Jan 29, 2008 | 05:29 AM
  #40
MR Turco's Avatar
bump for more input.
Old Jan 29, 2008 | 08:11 AM
  #41
wshihdnevo's Avatar
It was night and day for me and only took like maybe 30 minutes to do if you know what you are doing and I used the evomoto writeup on it. It made a big difference from before to after removing it. I now have a different clutch and ss line, but I ran just the restrictor pill removed for awhile before my stock clutch didnt want anymore drag racing. I got like 40k+ miles out of my clutch. And like most people have said, removing this does nothing that hurts the clutch, if anything it helps the longevity of it.
Old Jan 29, 2008 | 09:49 AM
  #42
C6C6CH3vo's Avatar
I just bored out and increased the oriface diameter to about midway from stock to having it removed. Much easier to controll and slip.
Restrictor is there to fry clutch instead of tranny for joe consumer driving
Old Jan 29, 2008 | 09:51 AM
  #43
LilRico's Avatar
With all that said: Have you removed the pill yet?
Old Feb 1, 2008 | 08:37 PM
  #44
MR Turco's Avatar
I did end up ordering a clutch line. It should be in next week and hopefully i will have a chance to install it. It is cold so i dont really feel like working on the whip.
Old Feb 1, 2008 | 09:03 PM
  #45
mrich82's Avatar
You'll notice a different not only with launching or high rpm shifts, but also normal driving. The clutch will have a consistent engagement point which isn't there with the stock clutch/line/pill. I did the ss line and pill removal at the same time, but it was a big difference. It really makes it feel like it should feel.. if that makes sense.
If you haven't done the shifter linkage bushings yet, this would be a good time to do that as well.. you will get better clutch pedal feel from the line and pill removal and better shifter feel from the bushings all at the same time. Its these little things that make the car more enjoyable to drive.. whether it be spirited driving or just plain old around town driving.
