SRS light is on
Old Jan 29, 2008 | 01:42 PM
sirevo8lancelot's Avatar
SRS light is on
I changed out my fog lights and the SRS light turned on after the install. any idea how to get rid of it?
Old Jan 29, 2008 | 01:56 PM
ok so i read some threads and apparently other peeps have this problem. i tried to take it to the dealership and they told me that they dont wanna mess with my car. is there anyone in the so cal area who can fix this. i definitely don't wanna bring my car to autozone or pep boys. Does anyone know of a dealership who is cool with modified cars and has done this before?
Old Jan 29, 2008 | 01:59 PM
Silver06evo9mr's Avatar
mine came on too dealer said its something with the device in the seatbelt. need to get it fixed but havnt found time. clear code and if it comes back on then take it to dealer
Old Jan 29, 2008 | 02:38 PM
EvoJoeIX's Avatar
pep boys or autozone will not have the scanner for the SRS systems anyway. it will need to do to the dealership to get it turned off
Old Jan 29, 2008 | 04:10 PM
gsrboi80's Avatar
You will not be able to clear the code with A standard OBDII scanner. You'll need a scanner that can talk to the Mitsu SRS system. Its an expensive program that alot of bodyshops will have installed in thier Snap-on scanners.
Try local bodyshops a dealer will bang you 100+ just to pull the code. Chances are you did one of two things
1. Didnt disconnect the battery while instaling the lights
2. If you did disconnect the battery you disconected the Positive terminal first. For some reason the EVO doesnt like that somtimes and will trip the SRS light. I guess it must see some sort of bad signl in the circuit. Ive seen this happen to a # of EVOs
Old Jan 29, 2008 | 04:35 PM
mrich82's Avatar
I bet you unplugged the yellow plug near the headlight. Even if you disconnect the negative side of the battery this will generally make that SRS light come on. Try to find a body shop.
Old Jan 29, 2008 | 04:37 PM
rcheung's Avatar
9 out of 10 times that is the cause of the SRS light coming on .
Old Jan 29, 2008 | 08:25 PM
Jameson_IXMR's Avatar
Which plug, so I know to never remove it?
Old Jan 30, 2008 | 05:32 AM
rcheung's Avatar
Im not sure if they are the same on the 8s and 9s. On the 8s its the yellow plugs the radiator. If I remember correctly its the ONLY yellow plugs around there and cannot be mistaken for anything else. Yellow plugs mean "don't remove me unless you have an SRS scanner" in evo terms.
Old Jul 30, 2008 | 06:43 PM
k2boarder3187's Avatar
stupid stupid question but i am going to ask anyways for the hell of it..
Can tripping the SRS light cause the car to go in a "safety" mode and run rich??
Old Jul 30, 2008 | 07:11 PM
VRSF Tiago's Avatar
Nope, SRS is unrelated to performance.
I'm wondering if you can just unplug the battery terminal and wait a while for it to clear itself after you plug the unplugged cables back in?
Old Jul 30, 2008 | 07:18 PM
Thanks
And no you cant ive searched that...apparently theres a lithium ion battery in the srs computer system itself and can last for years
Old Jul 30, 2008 | 07:31 PM
kouzman's Avatar
the crazy thing is that i get the srs light but not all the time... sometimes i do sometimes i dont... i guess i will check the connection mentioned here and see if something is loose...
Old Sep 15, 2008 | 04:54 PM
wshihdnevo's Avatar
Resurrecting this thread. I have removed this yellow plug many times before but this weekend I forgot to plug it back in and usually I unplug even when the battery isnt disconnected and this time i started the car and it came on and wont go off, so anyone know if this can prob be turned off through evoscan?
Old Sep 15, 2008 | 08:18 PM
VRSF Tiago's Avatar
Easiest thing to do is just goto an Mitsu dealer, quick and painless
Germz925
Nov 24, 2016 11:04 AM
jimbo74
Lancer Troubleshooting
Sep 11, 2016 02:38 PM
bry04evo
Jun 6, 2016 07:08 PM
itsmeek
Mid-Atlantic Region
Aug 28, 2015 05:31 PM
richevo26
Feb 15, 2009 09:58 AM
