GSC S2 Camshafts
Old Jan 30, 2008 | 04:18 PM
Nomad4g63's Avatar
GSC S2 Camshafts
What springs & retainers are you using with these camshafts?
Old Jan 30, 2008 | 04:23 PM
cssaddictm4's Avatar
I had the GSC 280s (similar to the S3's) on stock valvetrain reving to 8000rpms. S2s I would think you could use on stock valvetrain as well as long as you're keeping a similar to stock rev limit. If not you can always upgrade to a dual spring retainer kit (supertech, cosworth, etc) and make sure you don't have valve float and the ability to rev higher.
Old Jan 31, 2008 | 08:19 PM
GregGSC's Avatar
the old 280s with there 10.67mm of lift is more like the S1 than the S3's 11.5mm of lift i wouldnt suggest running the s2's on stock springs.
As for what to run we offer valve springs and retainers in either a dual or single setup, supertech is also good, or even Kigley racings single behive springs if your going for 9k plus. stay away from ferrea, crower, and brian crower... the crower singles are actually less favorable than the stock to us.
Old Jan 31, 2008 | 09:30 PM
TTP Engineering's Avatar
Correct, I was about to answer that incorrect info regarding GSC 280s. They do not require springs and retainers. The S3 are for the ifarted2 and AMS leagues of 900-1000+whp 10000rpms extreme performance engines. Two totally DIFFERENT cam profiles.
Old Jan 31, 2008 | 09:48 PM
evolved83's Avatar
what is wrong with the crowers?
Old Jan 31, 2008 | 10:27 PM
Interesting, I called GSC directly and inquired about the lift on my cams, and was quoted an 11.5mm lift.
Old Jan 31, 2008 | 11:03 PM
Paul Nelson's Avatar
I was floating my valves at about 9200rpms with the Brian Crower Spring upgrades
Old Feb 1, 2008 | 06:55 AM
evolved83's Avatar
well at your power level everything is different...
Old Feb 1, 2008 | 07:10 AM
mymigi's Avatar
at that power level, everything is different...including idle sounds and rattles
Old Feb 1, 2008 | 09:44 AM
lol nah that was when i was 712 hp
Old Apr 10, 2008 | 11:50 PM
jezefink's Avatar
when you were floating your springs..what did it sound like..an ignition breakup almost?
au
Mar 30, 2015 04:57 PM
KcEvil8
Dec 8, 2014 07:21 PM
dnetcrawler
Oct 12, 2012 09:58 AM
flambouyantdude
Lancer Engine Tech
Jun 10, 2009 01:08 PM
bigjoe_evo8
25
Jun 5, 2008 09:01 AM
