Loud pop?
Old Feb 3, 2008 | 06:00 PM
evotuner04's Avatar
15 Year MemberLikedLoved
Question Loud pop?
I was driving last night, and i down shifted to 4th and pulled around 5-6k rpms i heard a loud pop and i have no idea what it was...it didnt do it in 3rd or 5th at that rpm range so does any have an idea? I checked the upper pipe and it wasnt loose at the connections/elbows....so i really dont know
Old Feb 3, 2008 | 06:14 PM
wrxedout's Avatar
backfire??? or maybe diff slap from the rear differential from letting off the clutch hard while driving. It sounds like a backfire or pop
Old Feb 3, 2008 | 06:16 PM
staatz's Avatar
misfire.
Old Feb 3, 2008 | 06:18 PM
34Turbo's Avatar
Misfire or the bottom end of the uicp connecting to the ic. However, if you had boost leak issues you would have felt it under load big time so probably backfire.
Old Feb 3, 2008 | 06:46 PM
sparky's Avatar
How high were you boosting at the time that the pop happened?
Old Feb 3, 2008 | 07:35 PM
LoCo4's Avatar
Sounds like backfire.
Old Feb 4, 2008 | 03:22 PM
PSI NRG's Avatar
did you match revs when you went into 4th? My car will make like a pop or a backfire as you will when I match revs my exhaust is also really straight so no back pressure equals high flow and lots of pops and back fires
Old Feb 4, 2008 | 06:32 PM
EvoDom's Avatar
fuel cut?.....prolly just a backfire
Old Feb 4, 2008 | 06:34 PM
EVOlution561's Avatar
you probably just had a backfire, I doubt you had a fuel cut.
Old Feb 4, 2008 | 07:28 PM
BOOSTEZ's Avatar
+1 backfire.
I loved doing this when I had my RX7 Turbo II with no cat!!
Old Feb 4, 2008 | 10:05 PM
kimchee's Avatar
I think it's a backfire, my car makes that noise sometimes
Old Feb 4, 2008 | 10:08 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
most likely backfire
Old Feb 4, 2008 | 11:06 PM
evotuner04's Avatar
yeah guys idk, like i said in the first post thats all i can really say...im running about 21-22 psi untuned, which should be taken care of in april but normally a backfire is just a pop isnt it? not something that you feel hard in the car is it??? Cause when i felt it i was like whoaaaaa.....k, off the peddle but i didnt happen at all in any other gear
Old Feb 4, 2008 | 11:08 PM
SixOneNine's Avatar
Check your spark plugs.
Old Feb 4, 2008 | 11:10 PM
evotuner04's Avatar
^plugs were just taken out and replaced like 2k miles ago, and that was the 2 coldest plugs on the ams site
