Converting WR8 to TME turbo
Old Feb 4, 2008 | 01:59 PM
EVO8LTW's Avatar
Converting a FP WR8 turbo to a TME is as easy as undoing a band clamp and swapping on a stock Evo8 cold side, right?
Thanks,
Rich
Old Feb 4, 2008 | 02:12 PM
scheides's Avatar
EvoM Moderator
No, the TME has a magnesium compressor wheel I believe. Yes, you can swap an OEM VIII center section (including turbine wheel, compressor, and compressor cover) into the turbine housing for the white rabbit, but that's NOT a TME. That's the equivilant of a 2005 OEM VIII turbo (10.5 hotside).
Old Feb 4, 2008 | 02:21 PM
EVO8LTW's Avatar
I thought a TME has a titanium turbine wheel and shaft, unlike the iconel wheel and shaft in the hotside of an 05 or Evo9 turbo? Never heard that a TME has a magnesium compressor wheel...
Old Feb 4, 2008 | 04:48 PM
Yogi_B's Avatar
You're thinking of the evo9 RS turbo, that had the mag comp wheel, the mag wheel was only first used on the evo9 RS turbos.
Old Feb 4, 2008 | 08:57 PM
sparky's Avatar
Just swap out the compressor wheels. You may wish to have the cartridge VSR(vibration sort rig)balanced at over 100.000 RPM, after the swap though.
Old Feb 5, 2008 | 02:30 AM
gtpumps's Avatar
This is correct.
The TME turbo has titanum turbine wheel and normal aluminium compressor wheel. How do I know this, because I have a TME
Old Feb 5, 2008 | 03:48 AM
EVO8LTW's Avatar
Originally Posted by gtpumps
This is correct.
So my initial post is correct then too?
dmcghie
Mar 31, 2010 07:49 PM
drush08
Oct 22, 2008 02:47 AM
EVO8LTW
27
Mar 26, 2007 08:21 PM
RaNGVR-4
Oct 5, 2005 07:08 PM
EvilBlueEvo8
68
Jul 26, 2005 10:18 AM
