Tommi makinen turbo differences.
Old Oct 3, 2005 | 11:27 AM
RaNGVR-4's Avatar
what exactly are the differences between evo 8 trubos and TME turbos (other than the 10.5 turbine housing). does anyone have exact flow numbers?
Old Oct 3, 2005 | 11:29 AM
Doogie Howser's Avatar
tme turbo have Ti wheel (I think not 100% sure)
Old Oct 3, 2005 | 01:44 PM
sspeed's Avatar
Some of the TME's (GSR) were 15G's vs Evo 8 16G's
Old Oct 3, 2005 | 01:50 PM
Gruppe-S's Avatar
The TME turbo shaft and compressor wheel are made from Titanium therefore its 30% lighter than a normal 16g. With that said, the TME turbo will spool around 300 rpm faster than a regular 16g and from my past experience, the top end power are better than stock.
Thanks,
Tom
Old Oct 3, 2005 | 09:25 PM
RaNGVR-4's Avatar
the better top-end would probably be due to the larger turbine housing i imagine. are the compressor wheel specs the same for the 16g versions?
Old Oct 4, 2005 | 01:36 AM
Yogi_B's Avatar
The better top end comes from the 10.5T ehaust housing verses the 9.8T for the evo8.
As for the wheels, yeah the 16G versions are the same.
Old Oct 4, 2005 | 02:55 PM
sspeed's Avatar
Thanks,
Tom
If you want real response...go with the TME GSR 15G turbo. You lose a bit of horsepower (10-15) but it spools like crazy and holds boost very well.
Old Oct 4, 2005 | 03:03 PM
BBYBruno's Avatar
*SEARCH*
There are probably over 10 different threads on the TME.
Old Oct 4, 2005 | 03:51 PM
EVOla_VIRUS's Avatar
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
TD05HRA-16G6-10.5T (RS/rs2)
Nozzle Area (cm2) = 10.5
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Off topic: Cool thing is the Dodge SRT4 Stage 3r is offered with the specs of the TME turbo (GSR) which is the TD05HR-15GK2-10cm2
http://www.mopartsracing.com/parts/neon.html
Old Oct 5, 2005 | 07:08 PM
RaNGVR-4's Avatar
thats exactly what i said. you evo guys call turbine housings hotsides or exhaust housings.
XRims
Apr 20, 2010 03:53 PM
Methodz4life
75
Feb 16, 2009 11:39 AM
mmartahus
Mar 30, 2008 11:35 PM
lancer r us
Lancer Aftermarket Forced Induction Tech
11
Sep 26, 2003 11:00 PM
