Can a GT30r run 11's?
here si the thing tho i have a hks ebc and ill be using the stock ecu could the tuners use the ebc to do a 93 mapa nd a race map i have two settign the the ebc A Setting and B settign each cna change boost so i woudl assuem they can do it ont hat can they not?
I just think it will be safer and more realistic with a little race gas, like I said I think you are going to be right there, but it will also depend on driving too. I have seen 35r's on race gas run 11.4 and I have seen stock turbo IX on 100 octane run 11.4
if its only once a month then it doesnt hurt to throw a little race gas in the mix.
on my 3065 I made just about enough power to run 11.4 with a 93-94 octane.
ya ill have them maybe do a 93 map and a race map but not str8 race maybe with a 1/4 of 93 in then fill it to half way with the race
but the ? i ahve is coudl they do that with the hks ebc coudl i siwtch back and forth thru the maps or woudl i need a whoel other switch to do it?
well it is a HKS EVC BOOST CONTROLLER V2
here is a link to what it can do
http://www.optionimports.com/hksevcbocov21.html
so i mean thats why i am wondering if i can just swap back and forth tot he settigns or woudl i need a laptop to do the switch since ful and everythign needs to be switched
you could have them do a general tune good for 93 pump say 22psi and 93/104 mix at 26psi but thats not going to optimized tune since its a general tune where you just bump the boost.
see thats the thing id o have a laptop but it smy sisters the thing is i ahve no ecu programs on i to even swapp over maps
so im thinking they can cusotm make a switch some where
cuz my freind has a audi s4 and to sewitch maps he holds done the cruise control button and wen it blinks 3 times that measn its on race map
so im thinking they can do somethign liek that wiht certain buttons on cars
SRY FOR BAD SPELLING i type fast
you want something like Cobb tuning Access Port then.
u think that woudl be a good choice to do wat i want to switch maps and everythign
woudl that be a good thing to use with ther stock ecu? i neevr used one b4 are they hard worth the money
I heard somewhere that ecuflash is coming out with a way to switch between two fuel maps by way of the intercooler sprayer switch. Not 100% sure if that's accurate but if it is, it might save you some money.
