Front O2 sensor question
Old Feb 6, 2008 | 03:40 PM
sabastian458's Avatar
I think this is the right area to post this.
I am wondering if I could solder in a wide band O2 sensor in place of the factory O2 sensor and the ECU be able to read what it needs to for its parameters? I dont expect it to be able to read the full scale or it to be used in place of a wide band.
Reason being, is that when trying to remove my factory O2 it stripped out in the cast housing. Now I have an extra AEM wide band sensor that is good, and I can not afford the $200+ for another factory sensor.
Old Feb 6, 2008 | 04:58 PM
no one?
Old Feb 6, 2008 | 05:01 PM
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
Without a front O2 sensor, your car will run pig rich and throw a CEL. I know because I just replaced mine last summer. EGT temps were lower than usual.
Hope this helps.
Old Feb 6, 2008 | 05:07 PM
wizzo 8's Avatar
I really dont think so.
Old Feb 6, 2008 | 05:24 PM
Kracka's Avatar
Get a non-Mitsu sensor. I believe I paid $56 shipped for mine. The wires were the proper length, it had the correct harness on it, and the car is running perfect and making great power! It also comes with a 12-month/12k mile warranty.
www.oxygengeek.com part # SN4-126
http://oxygengeek.com/item.wws?sku=S...tid=oxygengeek
Old Feb 6, 2008 | 09:47 PM
DrivinMissDaisy's Avatar
A regular o2 sensor goes from 0-1v. A wideband goes from 0-5v. You cannot hook up a wideband output to a normal o2 sensor input. If you have a something to convert the signal you can do it. I know the zeitronix can turn do it. It takes the wideband signal and produces a narrow band signal that you can hook up. I don't think the AEM can do that.
Old Feb 6, 2008 | 11:39 PM
Zeitronix's Avatar
Wideband O2 sensor needs to be driven by a complex electronic circuit but a narrowband O2 sensor generates readings on it's own. You need a wideband controller to drive a wideband O2 sensor.
Old Feb 7, 2008 | 05:24 AM
ah, interesting information. Thank you everyone
Seancj
Jul 14, 2015 02:45 PM
slostjoe
Dec 15, 2013 06:14 PM
superkizuna
Apr 13, 2012 04:04 AM
jerrymldz
12
Oct 13, 2007 08:22 PM
denial
Apr 12, 2006 02:17 AM
