Rear subframe torque specs and others
Old Feb 8, 2008 | 10:27 AM
cal1mr's Avatar
I will be installing the buscher moustach bar and beatrush diff bushings soon. I can't seem to find the torque specs for the rear subframe bolts, the side diff carrier bolts, the diff cover to moustach bar bolts, or the moustach bar to subframe bolts. Any help with these would be great. Thanks
Old Feb 8, 2008 | 09:38 PM
cal1mr's Avatar
bump.
Old Feb 9, 2008 | 01:36 AM
blackevoguy's Avatar
This should help
https://www.evolutionm.net/forums/sh...d.php?t=222551
Old Feb 9, 2008 | 08:52 AM
cal1mr's Avatar
Thanks alot. I don't know why I didn't get this when I searched "torque specs". Still though, it does not give torque for the diff side carrier bolts, the diff cover to moustache bar bolts, or, unless I'm missing it, ALL the subframe to body bolts. I'm not sure what the bolts designated by "13" are fastening, is that the subframe? I suppose if it is then there would be a total of 6 "13"s, correct. Please verify. And if it's not too much trouble, what's the torque for the moustache bar to subframe bolts? Almost forgot about this one.
Old Feb 15, 2008 | 09:54 PM
cal1mr's Avatar
bump. One last try
blackbalts
Jan 27, 2016 06:08 PM
deeman101
Oct 27, 2014 11:28 PM
wesside
Nov 6, 2012 12:42 PM
stevef
May 13, 2012 11:04 PM
cal1mr
15
Aug 13, 2008 01:09 AM
