Read My Plugs
Old Feb 11, 2008 | 07:00 PM
felickz's Avatar
Read My Plugs
I am an EVO newb... Not too sure how to read my plugs... maybe you can offer me a suggestion.
After three 2 minute trips in ~20 degree weather yesterday, i went to pull my evo in the garage and it started bad and sputtered into my garage. I figured it was some cold weather bug, but when i went to start it this morning ( in my garage at around 40 degrees) it wouldnt start.
Battery looks good(tried using jumper pack), engine cranks hard, i smell fuel BUT no start. Plugs were wet and smelled of gas.. but i did try to crank it about 10 times today...
Do you think i could have flooded the engine with my quick trips in the cold weather, and not letting the engine get to temp? Right now i have the plugs out and i am hoping the gas will evaporate and things will be all better...
Anywho.. Can you give me some advice on these plugs:
NGK IR 1LFR7H:
high res: http://home.dejazzd.com/mandyleep/EV...evo_plugs1.jpg
Thanks!
Old Feb 12, 2008 | 08:59 AM
felickz's Avatar
Should i just clean off the carbon or is it time for new plugs?? I have no idea how many miles are on the plugs. (well a max of 30k)
Old Feb 12, 2008 | 10:21 AM
ODUB's Avatar
time for new plugs. mine looked like that after 60k miles. i just changed them. sparkplugs.com can get you a new set for like $40 so just get rid of'em.
Old Feb 12, 2008 | 06:51 PM
felickz's Avatar
new plugs ($52.36) and she started and ran fine. Thanks! (just in time for the snow fun too!)
Old Feb 12, 2008 | 09:36 PM
TTP Engineering's Avatar
Those plugs are fouled from fuel or oil or both. Check your tuning.
Old Feb 13, 2008 | 09:27 AM
felickz's Avatar
I may need to hire your help as the car i bought was tuned by you! ( i believe he used your tune as a base and added ecu controlled boost though)
Old Feb 13, 2008 | 09:36 AM
There is no telling what combination of parts is in the car now. Many will buy an eflash, than change a number of things, not limited to intake which is a big no-no. Something as simple as a boost leak would cause a major rich condition into the 9's AFR.
Old Feb 13, 2008 | 12:30 PM
felickz's Avatar
Actually he was really knowledgeable about tuning, DanInPA if you remember him.
Only extra parts are a drop in filter, and a turbo back exhaust. Boost peak at 21 psi. maybe some cold weather tuning is in order, since that seems to be what put the plugs out of their misery.
Jon91TSi
For Sale - Part Outs
44
Oct 9, 2008 08:02 AM
felickz
Sep 2, 2008 04:56 PM
Jon91TSi
Jul 6, 2008 09:02 PM
Jon91TSi
Dec 11, 2007 12:06 AM
Jon91TSi
Oct 31, 2007 03:49 PM
