I Think My Turbo is going tits up
Old Feb 11, 2008 | 10:31 PM
h.funk's Avatar
I Think My Turbo is going **** up
I have a new high pitched whine when the car is boosting. I have checked all the hoses and found no leaks. The car has 10k daily driven miles and sits in the garage most of the time. How do you tell if the turbo is going south? I dont think its the t case cause everything in the drive train feels fine. Any thoughts?
Old Feb 12, 2008 | 06:10 AM
BOOSTEZ's Avatar
How can that car give you ANY problems with just 10k on it??
Maybe it wants you to drive it?
Back on topic:
The easiest way to tell about the turbo going bad is to check for a bad oil seal. Unfortunately unless take apart the turbo, it will be hard to diagnosis. One quick way is to let the car sit and idle for about 30 minutes or so (till the cooling fan goes off and on several times). Look at the exhaust and see if there is any blue smoke seeping out of it. Of course that could be other things too.
You may also have an exhaust manifold bolt loose which will cause this whistle noise, but that usually goes away after the car is warm.
Old Feb 12, 2008 | 06:35 AM
C6C6CH3vo's Avatar
Check the shaft for play
Old Feb 14, 2008 | 09:58 PM
h.funk's Avatar
Thanks. I think that I am gonna take it a part and look at it. It seems to be driving fine but the new sound is very concerning.
Old Feb 14, 2008 | 10:02 PM
4WS Tuning's Avatar
warranty?
Old Feb 14, 2008 | 10:10 PM
h.funk's Avatar
My warranty is just about up so I will take it in. The sound is very high pitched and I can only hear it under boost.
Old Feb 14, 2008 | 10:35 PM
8UpUrV8's Avatar
**** up eh? very nice.
Old Feb 15, 2008 | 12:10 AM
dbsears's Avatar
Mine just started to do that too. Sounds like a supercharger kicking in at about 5000rpm. Wonder if its this cold weather? I was thinking maybe a pulley or belt tensioner...thats where my noise seems to be coming from.
Thahomeboyb
Lancer How Tos / Installations
Dec 20, 2013 06:18 AM
amsevokid
Jul 19, 2013 06:53 PM
bighead87
12
Aug 2, 2012 06:04 PM
Tims2006MR
11
Aug 23, 2010 02:04 PM
dambikeracer
29
Jun 16, 2009 10:26 PM
