Should I be disappointed DYNO GT30R
was looking around and i found this....
looks like EBAY intercooler when it comes to cooling probably isnt the issue like i said.
Default 2 liter, BR GT35r header kit, EBAY (AMS STYLE) FMIC
Starting AIT 64.40 degrees
Ending AIT 122 degrees
Peak boost 42.1 psi
20 psi at 4563 rpm
2.3 liter, AMS GT35r, AMS standard FMIC
Starting AIT, 102.2 degrees
Ending AIT, 134.6 degrees
Peak boost 23.98 psi
20 psi at 4551
2 liter, HKS 3037, AMS standard FMIC
Starting AIT, 104 degrees
Ending AIT, 125.6 degrees
Peak boost, 23.57 psi
20 psi at 4691 rpm
2 liter Turbo Trix T3, GT35r kit ETS 3.5" FMIC
Starting AIT 105.8 degrees
Ending AIT 129.2 degrees
Peak boost 36.31 psi
20 psi at 5086 rpm
some random intercooler temps that were put together for some numbers.
here is the link if interested in more numbers.
http://buschurforums.com/forum/showthread.php?t=20445
Peak boost 42.1 psi
20 psi at 4563 rpm
20 psi at 4551
20 psi at 4691 rpm
20 psi at 5086 rpm
Peak boost 42.1 psi
20 psi at 4563 rpm
20 psi at 4551
20 psi at 4691 rpm
20 psi at 5086 rpm
Peak boost 42.1 psi
20 psi at 4563 rpm
20 psi at 4551
20 psi at 4691 rpm
20 psi at 5086 rpm
Ebay intercooler: 58* rise
AMS 1: 32* rise
AMS 2: 21* rise
ETS: 24* rise
Looks to me like the ebay intercooler has some issues with about 2 to 3 times as much temperature rise during one pull.
-Paul
How can you conclude that the Ebay intercooler is NOT the issue from that data?
AMS 1: 32* rise
AMS 2: 21* rise
ETS: 24* rise
-Paul
AMS 1: 32* rise
AMS 2: 21* rise
ETS: 24* rise
-Paul
Also, this is after one pull imagine after a couple...
Scorke
Ya no shizel !!!!!!!!!!!!!!!!!!
QUOTE=Miralution;5315293]I made 442 at 29 psi on BR 3065 cast iron manifold on 100 octane at mustang dyno on a BONE stock motor w/ WORKS 269 cams... that is kindda low for a c16 fuel.[/QUOTE]
How much timing can you get away with running C16 WOT,,,,,
pwned myself good one.
i was just giving some examples grow up. i was showing that ebay intercooler isnt the problem then i showed how other good intercoolers had similiar temperatures.
i made my point.
i made my point.
If your point was that you didn't understand the data and couldn't figure out that the ebay intercooler does not work nearly as well as the others, then yes, you did make your point.
