EVO wont start?!??
Old Feb 25, 2008 | 03:26 AM
huevosrancheros's Avatar
EVO wont start?!??
Hey gentlemen, my best friend's EVO 8 wont start. I have No CEL, the battery is 100%. The motor has about 60000 miles on it. He bought the car used. The only mods the car had is a DEFI boost gauge.
The car will not turn on. The fuel pump is good, because is turns on. I have yet to check for spark.
This is an intermitent problem. I believe it is a bad ignition coil.
Can you give me some ideas guys.
I have checked all sensors and all vacuum lines everything is connected.
Old Feb 25, 2008 | 03:43 AM
sharkm87's Avatar
Originally Posted by huevosrancheros
Hey gentlemen, my best friend's EVO 8 wont start. I have No CEL, the battery is 100%. The motor has about 60000 miles on it. I bought the car used. The only mods the car had is a DEFI boost gauge.
lol, first u say its your friends evo, than you say you bought it used and you have no cel, and you you you... ...
hopefully the guys will chime in to help you, i mean "your friend out"
..well i'm sure they will ask whats happening exactly when you turn key,...is motor trying to turn over?
what happened before it couldn't start, where u racin it hard and it died on you, or you just woke up in the morning and bam, wouldn't start?
is there gas in the car?
check plugs, coils....all the basics
Old Feb 25, 2008 | 06:40 AM
Burklow's Avatar
You can hear the fuel pump whine? Wow. You must have good ears. I could only hear it when I removed the rear seats.
Old Feb 25, 2008 | 06:47 AM
rcheung's Avatar
If a walbro 255 is in there, the whine is sometimes incredibly loud.
Old Feb 25, 2008 | 07:04 AM
SixOneNine's Avatar
Maybe "your friend" Evo's alternator is out?
Old Feb 25, 2008 | 10:42 PM
any more ideas from you fine intellectualized gentlemen
Old Feb 26, 2008 | 06:03 PM
sharkm87's Avatar
no, you haven't even attempted what was presented to you thus far. do that first and relay your conclutions.
Old Feb 27, 2008 | 10:06 PM
yes sir I have already the aforementioned solutions.
The car cranks over, the alternator is good, the battery is brand new. THe terminals are well grounded. Everything turns on. The fuel pump pressurizes and kicks on. I checked all the fuses I could check w/ a snap on diagnostic light.
On my inspection of the fuses I noticed that the diagnostic light was reading weak on the fuses closest to the ECU relay. I suspect something is drawing voltage. The starter cranks the motor over.
I read the possiblity the ignition coils could be going bad.
Old Feb 27, 2008 | 10:11 PM
[QUOTE=sharkm87;5327974
check plugs, coils....all the basics[/QUOTE]
My buddy didn't race it, drive it hard or do anything out of the ordinary. He just went to walmart and the ****er didn't start. He came back later it turned on just fine and drove fine. It did it again at his apartment complex and then finally it did here at work and eventually it didn't turn on again.
Old Feb 27, 2008 | 10:15 PM
ApacheFixer's Avatar
short in the starter?
Old Feb 27, 2008 | 10:26 PM
could be, It just sucks because it's so cold outside to do anything. First thing first I have to get his lazy *** to tow the car to his garage so that we can work on it.
I suspect is the defi boost gauge that was installed on the car. I was looking at the wiring that goes through the firewall it was frayed a little bit.
Old Feb 27, 2008 | 10:33 PM
AJsGenerX's Avatar
My friend wired his megan racing boost gauge in his IX. He ended shorting out the car. It started on occasions and simply clicked on others. Definitely check all the electrical connections with the boost gauge.
Old Feb 28, 2008 | 08:41 PM
I like this idea alot w/ relay info to lazy friend.
Old Feb 28, 2008 | 09:06 PM
beomoua's Avatar
Does it turn over or just clicks? If it just clicks...starter. If it turns over but doesn't catch and you have been turning it over for a long time, I would say it is flooded.
Old Feb 28, 2008 | 09:23 PM
KcEvil8's Avatar
have u check for sparks yet?
