30K Service
Old Feb 28, 2008 | 09:02 AM
stryfetew's Avatar
How did everyone do it that did not take it to the dealer I have the fluids just no access to a lift. I know it needs to be on level ground to be done.
Old Feb 28, 2008 | 09:03 AM
rcheung's Avatar
Originally Posted by Burklow
I believe Mitsu charges around $500 for this service. How much did it cost DIY?
About 50 bucks.
Old Feb 28, 2008 | 09:04 AM
rcheung's Avatar
Either 4 jack stands or ramps in the front and jackstands in the back.
EvoPooPoo's Avatar
For transfer case / rear Diff
1 can of KAAZ Powertrain Gear oil: $45.00
1 small plastic fluid pumper thingy...: $6.00
...and about 1/3 can still left for the next fluid change.
about 1.5 hours of your time (including cleanup)
For tranny:
Haven't done this on my evo yet. Fluid was changed with the clutch...so...yeah...
but couple quarts of good gear oil shouldn't run you over $35.00
Old Feb 28, 2008 | 09:08 AM
evo9mr0006's Avatar
Someone should make a write up on how to do this wacky ****
Old Feb 28, 2008 | 09:18 AM
rcheung's Avatar
http://www.socalevo.net/forum/index.php?topic=2682.0
Old Feb 28, 2008 | 09:22 AM
eckorex's Avatar
I just pay someone to do it. I stay clean and it's not that expensive.
Old Feb 28, 2008 | 09:24 AM
Drooke's Avatar
so should I just use the dealer ship fluids ???
Old Feb 28, 2008 | 09:36 AM
cheb evo's Avatar
Just make sure that the dealership actually stocks Diaqueen. Some dealerships I have talked to have never even heard of it. Plus, if a dealership does not know the proper fluids to put into the car, I wouldn't really trust them to do the work. Plus like other people have said, it is really easy and cheap to do on your own.
Old Feb 28, 2008 | 09:40 AM
Drooke's Avatar
k I just really need it done so what are the best fluids ?
Old Feb 28, 2008 | 09:48 AM
SPANKED's Avatar
Originally Posted by NEpsiOver21
I had my tran fluid changed at 19k miles cuz i had a new clutch put in but i didn't really feel a difference. =/
That and my 5th gear grind was still the same...
What tranny oil did you use?
I did my tranny at about 17k with super diaqueen and it did not remedy my 5th gear synchro grind that just started before changing the fluids. I may try MT-90...
Old Feb 28, 2008 | 09:55 AM
lords3t's Avatar
OEM fluids all around (you can get them pretty cheap from mitsubishiparts). If you can change your own oil, you can change your tranny... um... oil!! It's the same deal with the exception of opening the fill hole before the drain plug.
My question is, has anyone dared do the belt service themselves yet? I'd love a nice write-up on THAT one.
Old Feb 28, 2008 | 10:35 AM
Burklow's Avatar
Originally Posted by rcheung
About 50 bucks.
That's what I thought.
Let me rephrase that... WHY does Mitsu charge $500 for the service?
Old Feb 28, 2008 | 10:40 AM
lords3t's Avatar
^ because most people do not understand how easy it is to do this. You hear the word Transmission and most people think it's some rocket-science complicated thing. I've even heard of some shops (not dealers in all honesty) saying that they had to open up the transmission to accomplish these services. More than likely they're just referring to certain AT that require you to actually open up the under pan to dump the transmission fluid. Clearly, manuals are not like that.. nor are any of the newer transmissions for that matter.
Old Feb 28, 2008 | 10:42 AM
m98evolution's Avatar
I changed my tranny fluid with the Nissan oil, its the same spec as called for from the manufacturer. Noticed a great difference! What have you guys done about your ACD fluid?
