Intake help
Old Mar 2, 2008 | 09:47 PM
hokiruu's Avatar
- Route the vacuum hose from the MBC to a nipple you will find on the the turbo housing itself. Pay attention to where the lines from the boost solenoid are or aren't. Stock they go to where to route your MBC. Also make sure that the other hose from the MBC goes to the wastegate.
- Route the vacuum hose from the DV to one of the dark appropriately sized nipples you can see coming from the valve cover area.
- The other nipple from your intake tube itself should go to the breather valve on the front right corner of your valve cover.
Hope that helps sorry I'm tired.
Old Mar 3, 2008 | 05:28 PM
phabaznbro's Avatar
Ok i have the breather valve hose right
So there is another nipple on the intake, is that where I should attach the hose from the MBC?
Then route the hose from the DV to essentially where the "T" originated from correct?
So right now I have an extra hose right?
Old Mar 3, 2008 | 07:03 PM
phabaznbro's Avatar
anybody? thanks in advance
Old Mar 3, 2008 | 07:11 PM
wizzo 8's Avatar
That metal line that you have the hose with tee attached goes to the MBC and the BOV.
Old Mar 3, 2008 | 07:15 PM
jmoudry's Avatar
Check out this thread on a mbc install it has some good diagrams: https://www.evolutionm.net/forums/sh...d.php?t=114794
mouaboost
Aug 1, 2017 06:04 AM
DailyRally
Feb 25, 2017 05:00 PM
sp00lin9
10
Feb 27, 2016 03:09 PM
wenbenten
Feb 4, 2012 06:24 PM
sti"izzle"
Sep 21, 2010 01:31 PM
