Intake help
Old Mar 2, 2008 | 04:29 PM
phabaznbro's Avatar
Intake help
Ok before I begin i will be getting a tune very shortly from mellon and i realize thats why my a/f ratios are crap and my car wants to stall at a dead stop. My question is should this affect boost levels? I was boosting around 21 psi before I installed the injen air intake and uicp, now i only peak at 15. I have a mbc and didn't touch it at all during install. Also, the DV seems to be backfiring for less of a better term, is that normal before a tune?
I'm not experienced with working on my car and this was my first real project, so i just want to see if it could be anything with the set up itself...
Thanks...flame suit on
Old Mar 2, 2008 | 04:35 PM
psphinx81's Avatar
is your bov on backwards?
Old Mar 2, 2008 | 04:41 PM
phabaznbro's Avatar
def a thought of mine....too dark and too cold by the time i finished to check, any other ideas what it might be?
Old Mar 2, 2008 | 04:43 PM
chaotichoax's Avatar
check your diverter and make sure your intercooler piping connections are nice and tight...ater you check the diverter valve do a boost leask test
Old Mar 2, 2008 | 05:00 PM
phabaznbro's Avatar
will do, thanks!
so i'm assuming there is definately something wrong with my set up, how much harm is it going to cause to drive without a tune, i drive daily but only a short distance..figure no point getting a tune til i fix the install issues
Old Mar 2, 2008 | 07:47 PM
phabaznbro's Avatar
ok so i found the problem i think, take a look
anyone have any idea where this is suppose to attach to? The "T" attaches to my MBC
also i switched the BOV as suggested, this is how its positioned now, thoguhts?
THANKS!
Old Mar 2, 2008 | 08:11 PM
phabaznbro's Avatar
anyone?
Old Mar 2, 2008 | 08:17 PM
Billy@EnglishRacing's Avatar
is it running well after you made those changes?
Old Mar 2, 2008 | 08:19 PM
beomoua's Avatar
Switch you bov back, you've got it backwards.
that hose is suppose to go to your bov nipple. i don't know how you hooked up your boost controller, but i have mine from the turbo nipple to the bottom the mbc and from the wastegate to the side of mbc. i didn't tee mine off to the bov vacuum source.
Old Mar 2, 2008 | 08:24 PM
jmoudry's Avatar
Looks like your DV(BOV) is backwards now and the vacuum line should go to the top of the DV. Without that line the DV will not work correctly. Also with that end open you have a vacuum leak.
Old Mar 2, 2008 | 08:25 PM
jmoudry's Avatar
^ beat me to it. I agree with using the turbo outlet nipple instead of the T.
Old Mar 2, 2008 | 08:35 PM
beomoua's Avatar
i guess i am just that much faster...hahaha...j/k
Old Mar 2, 2008 | 08:38 PM
jmoudry's Avatar
I need to work on my typing skills.
Old Mar 2, 2008 | 09:00 PM
hokiruu's Avatar
Yes your DV is backwards. Also as others have said it is also not ideal to have your MBC teed off the DV vacuum line. Once you put the DV back on properly and eliminate the MBC tee off the DV and put it on the turbo nipple instead, your car should run right, assuming the intake itself and/or tune is not a problem.
Old Mar 2, 2008 | 09:30 PM
phabaznbro's Avatar
Thanks for the help, I'll give your suggestions a shot tomorrow.
Quick questions though:
Right now obviously the open end of the tube goes no where, the bottom of the T is going to the left (as i have it set up) of the MBC, where does the other end go? Just trying to learn a bit here (majorly inexperienced with working on my own car)
There is only one hose coming out of the DV correct? So thats suppose to mate up to the left of the boost controller? There is a nipple of the actual intake pipe, what is that suppose to attach to?
Thanks guys, really appreciatte the help
