Another best bang for the buck mod!!!
Old Mar 5, 2008 | 10:19 PM
RuckerPark's Avatar
Just installed the Blox Racing Front engine roll stopper and all I can say is wow!
Shifting engagement is much more smooth, precise and direct. I don't get any more 1st to 2nd grind and the occassional notchiness is no longer present!!! Throttle response seems to pick up a bit as well.. not sure if this is the placebo affect but regardless, im happy with this mod because the part is cheap and the result is great!!!
The only thing..well I don't even think this is a bad thing, is that you do get a slight vibration in the cabin now but its understandable since the movement of the engine is now much more stationary so the vibration is a given. I can live with this.
Overall I give this product a
If you have trouble in shifting and gear engaging, I highly recommend this modification!!
Here is a pic from Speed Element. I got the silver one instead.
Old Mar 5, 2008 | 10:21 PM
Warrtalon's Avatar
Hey, yeah, it's a good mod, but this is like 2 years behind. I did this exact write-up with much more information over 2 years ago.
Old Mar 5, 2008 | 10:23 PM
dxbevo9's Avatar
yeah...those lower engine mounts are incredible..i didnt believe it until i tried it..i have the agency power mount though..and that thing does miracles to shifting...
Old Mar 5, 2008 | 10:24 PM
lucky13evo's Avatar
^well its always nice to be reminded.. i am thinking about doing th same mod.
Old Mar 5, 2008 | 10:25 PM
dxbevo9's Avatar
where have you been Warrt? i mean you havent posted in ages...
keep up the negative posts!! hahaha
PnutButterWolf's Avatar
got mine as well. definitely worth recommending to all evo viii and ix owners
Old Mar 5, 2008 | 10:40 PM
gtfour43's Avatar
Damn I might have to give one of these a try. My shifting from 1-2nd is a little notchy at times. How much are these?
Old Mar 5, 2008 | 10:50 PM
06 EvoIXer's Avatar
ya RuckerPark, where did you get yours??
Old Mar 5, 2008 | 10:51 PM
Warrtalon's Avatar
They start at ~$40 and go up to $100 depending on which type you get. You can get ones that replace the whole bracket or ones that are just the bushing that you insert in place of the old bushing.
Old Mar 5, 2008 | 11:20 PM
RuckerPark's Avatar
got it from speed element. The link is here: https://www.evolutionm.net/forums/sh...d.php?t=319269
Old Mar 6, 2008 | 06:36 AM
Aby@MIL.SPEC's Avatar
i lke how the web link reveals a durometer reading of 90.
does any one know of other makers that specify their durometer reading for their bushings?
i also like the idea of swapping out the mount entirely vs. removing the oem bushing from the mount.
Old Mar 6, 2008 | 06:37 AM
MR Turco's Avatar
I just got one of these. I cant wait to install it.
Old Mar 6, 2008 | 08:11 AM
evospecialist's Avatar
i use powerflex front engine,lower front and trans side = sweet
Old Mar 6, 2008 | 08:51 AM
Bora's Avatar
Ok, so I'm having the Notchy shifting also what other mods besides this one can help with that. It is annoying from 1 to second and really bad from 2 to 3rd.
Old Mar 6, 2008 | 10:55 AM
Did you try this mod already? I had the same issue as yours and this mount basically eliminated the notchy shifting of my evo.
Perhaps you should give it a try because its only $75 and it literally only takes about 20min to install.
