Max boost on FP GREEN
Old Mar 9, 2008 | 02:31 PM
extremier's Avatar
Hi. I did get a FP Green with 10.5mm nose and the better actuator...
So What is a Good high boost level on this Turbo?
My setup has: Full blitz exhaust, and 272 cosworth , 1200 cc injectors ! besides...
I,m from Brazil, and here we have ethanol on fuel pump at regular gas station...
This is my fuel, usualy takes 20% more feed than gasoline, but also allow a bit more boost and power.
Thanks a lot.
Mario
Old Mar 9, 2008 | 06:54 PM
9sec9's Avatar
On the street tune, we run a high of 32 with that actuator and 101 +water/meth injection. The turbo really likes the 30psi and up range. Max boost would be based on fuel and tune, but ours runs best on a race tune of 37psi with Import race fuel. Hope that helps. The FP actuator holds boost better in the midrange, so watch your timing closely.
Old Mar 9, 2008 | 06:55 PM
Billy@EnglishRacing's Avatar
i have seen 30 pounds on pump on the street with no knock
Old Mar 9, 2008 | 09:26 PM
sparky's Avatar
I am impressed! Is this on a VIII or a IX? Seeing that you are experiencing no knock at 30 PSI, then, at what boost level do you actually start to see knock on pumpgas? Maybe you should tune my car for me.
Old Mar 9, 2008 | 10:49 PM
quick silver 8's Avatar
i've done 30 on 103 and it ran great
Old Mar 9, 2008 | 11:24 PM
evospecialist's Avatar
i have seen 36 psi on meth hehehehe awsome ride
Old Mar 12, 2008 | 03:39 PM
JDMevoBOOST's Avatar
1200cc injectors for a stock sized turbo?? Man u are nuts....
Old Mar 12, 2008 | 03:46 PM
MillDogg13's Avatar
I run 30.5 psi on C-16 with the stock actuator, this is my conservative race tune.
Old Mar 12, 2008 | 03:59 PM
evoPirate's Avatar
He is using ethanol fuel, needs bigger injectors to get enough juice
Old May 28, 2014 | 06:26 PM
EvoTurboTurk's Avatar
What would be the maximum boost psi for a FP RED Ball Bearing turbo?
Old May 29, 2014 | 09:09 AM
YogSaahoth's Avatar
Veteran: Army
Man I should really start looking at original post dates lol
Old Jun 1, 2014 | 01:16 AM
jwdp54's Avatar
I run 35-37psi making around 520hp
Old Jun 2, 2014 | 03:10 AM
Thats with the green ball bearing?
ohmohm
31
Dec 12, 2015 12:00 PM
scothu
16
Feb 16, 2014 04:50 AM
winkdogydog101
11
Oct 9, 2012 03:56 PM
Kawboyz11
11
Nov 21, 2011 04:30 PM
SS2EVO
21
Nov 10, 2011 08:15 PM
