Spun rod bearing. What to do ?
Old Mar 11, 2008 | 06:42 PM
RoadSpike's Avatar
Originally Posted by newimportowner
Come on are you serious. I have never seen my local NAPA ever regrind a crankshaft. that must be a california thing maybe but seriously, are you serious? if so I suggest you see a Counselor. no offense.
My NAPA has a machine shop here I just assumed others would as well
I don't know why your so offended these guys are basically going to position a crank in a lathe and have a computer do the work. Pay NAPA or some other machine shop its all the same in my eyes.
Old Mar 11, 2008 | 06:46 PM
Oil Doc's Avatar
Grinding Cranks is a very accepted practice... mare than that.. it is the norm.. just like re-grinding a cam to a different profile.
Doc
Old Mar 11, 2008 | 06:54 PM
David Buschur's Avatar
Don't short cut this build/fix. If you do you will greatly regret it both financially and the time you waste.
Do not turn the crank, do not re-use those stock rods, there is an entire list of DO NOTS, miss one of them and you'll be doing it all again.
Old Mar 11, 2008 | 06:55 PM
TalonTuner4G63's Avatar
4G63 cranks have a factory nitride coating which gives them their strength. Turning the crank takes away this coating, which is why I don't believe in turning these cranks. This isn't a small block Chevrolet. Find another crank, and rebuild the bottom end. If money is tight, don't do it anything with it at all untill the funds are available to do it right.
Old Mar 11, 2008 | 07:02 PM
Originally Posted by Liqquid
did you ever figure out why the thing went in the first place? Inquiring minds who own bearings want to know
Mabey he was running Mobil1 10W30
Old Mar 11, 2008 | 08:54 PM
RoadSpike's Avatar
Curious to know what happens when you dont
You obviously build a lot more motors then most anyone here so I figure your advice will be gold.
Dannievo
16
Apr 26, 2015 08:54 PM
omniprobe
Apr 20, 2008 11:47 PM
liljj2221
Oct 23, 2006 08:51 AM
vegasboy301
15
Dec 27, 2005 08:12 PM
KazzEvo8
12
Jun 14, 2005 07:42 PM
