I spun a rod bearing !! :(
Old Jul 25, 2009 | 03:47 PM
Dannievo's Avatar
Well, about 600 miles ago my i changed a bearing in rods becouse of failure in 4 cyl and i just dropped a new bearings in it and i messure the clearance and the where prefect on all rods. Today i spun a rod in 4 cyl and my crank and rod is f***ed. The main bearings and rod bearings cyl 1-2-3 are perfectly fine, why does this happen ? What could have cause this?
its a Stock crank and Eagle rods.
Thanks
Daniel.
Old Jul 25, 2009 | 04:07 PM
rgeier11's Avatar
More than likely the crank has some scoring or is not perfectly round. This will eventually "catch" the bearing and spin it in it's place. Especially after heating up and expanding a little. Remember, your bottom end tolerances need to be in perfect order, even more so with a high horsepower car.
Old Jul 25, 2009 | 05:54 PM
GTijoejoe's Avatar
Perhaps you have something clogging the oil passage??????? I dunno but very strange that you can damage two rod bearings in such short notice on the exact same rod.
Old Jul 25, 2009 | 06:10 PM
project_skyline's Avatar
Could be oil contamination. What caused number 4 to fail in the first place? You always replace the oil cooler and purge all the lines when something like that happens.
Old Jul 25, 2009 | 07:05 PM
Dannievo's Avatar
Thats what i tought to, need to pull my motor apart and check the crank..
I think it was to rich. But the bearings now are alot worse than the last time...
Is it very bad for me to go oversize on rod bearings 0.10 ?
Old Jul 25, 2009 | 07:39 PM
nos51's Avatar
i would just replace the crankshaft,instead of cutting it to go oversized..it sounds like maybe lack of oil why it failed in the 1st place......
Old Jul 25, 2009 | 08:02 PM
+1
At this point you need to really tear into this and find out what has caused this, otherwise your looking at another failure in the future.
Old Jul 25, 2009 | 08:30 PM
Sievers's Avatar
You can not cut it, once you spin a bearing that crank is shot. You can go to a machine shop and check the hardness of the crank but most likely it'll be done. I have not even seen oversized bearings for these cars
Old Jul 26, 2009 | 09:26 AM
Dannievo's Avatar
I think your right, just replace the crank i think thats my next plan, but the car has never had lack of oil
+1
yep most likly its a clogged oil passage in the crank for cyl 4.. but i don´t know ..
hell of a situation
Old Jul 26, 2009 | 10:24 AM
KevinD's Avatar
did you plastigage the clearances when you put the new bearings in? my guess is the second bearing spun because something wasn't cleaned or replaced and bearing debris from the old one got into the new bearing.
Old Jul 26, 2009 | 10:31 AM
xspsi4's Avatar
Yup now you need to replace your oil cooler as well.
Old Jul 26, 2009 | 11:06 AM
Clutchdc5's Avatar
ouch, thats gonna cost...
Old Jul 26, 2009 | 01:26 PM
Dannievo's Avatar
Yes i did, i did the rod bearing and main bearings and it looked perfect
Well if this would happen to you i would have to pay 2x more than you becouse of the toll and shipping to iceland..
i need new bearings new rods, new crank
Old Jul 26, 2009 | 01:28 PM
nos51's Avatar
hell of a situation
how do you know?do you have an oil psi guage installed?
Old Jul 26, 2009 | 01:46 PM
c_penson's Avatar
if it was my car I'd also change the oil pump and check
the balance shaft bearings.
And once you spin a rod bearing the crackshaft is done.
