Removing Front Axles....
Old Mar 11, 2008 | 06:18 PM
PedroMartinez's Avatar
I am trying to remove the Front Passenger axle but it seems like its stuck on there it wont come out...
I have everything out of the way u can just sell the axles hanging in there. over the Lower control arm. I have removed the caliper off , rotor, hub and all....
is there a special way or tool to remove the axle... and yea its not in gear neither....
Old Mar 11, 2008 | 06:20 PM
idriveanevo's Avatar
use either a rubber mallet or place a piece of wood on the threaded end and hit it with a hammer....
Old Mar 11, 2008 | 06:35 PM
on the very end like near were the rotor used to be at?
Old Mar 11, 2008 | 06:39 PM
do i just hit it? trying to like brake her lose?
Old Mar 11, 2008 | 06:42 PM
typac69's Avatar
yea itll budge loose when you hit it and then itll come out. make sure you got the wood covering the threaded part though.
Old Mar 11, 2008 | 06:47 PM
Johnboy1065's Avatar
what I did was put a 17mm socket on the fill plug. then that gave me a good leverage point. then I would pry on the axle right were it came out of the transfer case. it's hard to explain. but if you just put the socket on there and get under there with a pry bar. you'd see what I'm talking about.
Old Mar 11, 2008 | 06:50 PM
correct, just like your tryin to push it through the hole
Old Mar 11, 2008 | 06:55 PM
well its late here in NC its dark outside will do that first thing in the AM
Old Mar 12, 2008 | 10:39 AM
ive been trying to snug here out all morning cant seem to her out....
Old Mar 12, 2008 | 11:02 AM
CO_VR4's Avatar
Some of the answers above are for getting the splines out of the hub. Others are for getting the inboard splined end out of the transfer case. It would be useful for you to clarify which end you're working on.
If it's the inboard end, you need to pry it out in a way that pulls it past the retaining snap ring, which is in a groove in the end of the axle that's inside the transfer case. A pry bar with the socket as a fulcrum (as described above) is one way to do it. You need to locate the prybar on the larger part of the axle housing, then hit it with the palm of your hand sharply to "snap" the axle retaining ring past the retention groove and release the axle. Sometimes turning the axle (spinning it a little) will help, while you use the pry bar.
Old Mar 12, 2008 | 12:23 PM
Well I FINNALLY GOT HERE OUT OF THE TRANSFER CASE. THATS WERE I WAS TRYIGN TO GET HER OUT.... had to bruise my hand up but im glad it came out lol
thanks guys for all the help...
Old Mar 24, 2008 | 06:36 PM
BaLListic_EVO's Avatar
i must have crazy skills or have done it plenty.... I can pop both axles out in no time....
Old Mar 24, 2008 | 09:27 PM
These damn Evo ones are the first ones that i have ever had trouble w/. No other cars gave me a single problem...
Old Jul 23, 2010 | 11:18 PM
NJ_EveOhVIII's Avatar
need to bring this back.
ive taken out my axles quiet a few times already. but for some reason the pass side will not come out of the hub this time. its usually simple the threaded side on the end doesnt slid in out like it used to its just stuck. is there a reason they get stuck or is it just dirt in there?
Old Jul 24, 2010 | 05:21 PM
MasterNater's Avatar
Sometimes the axle will get corroded or rusted in, where it splines into the hub. Have you tried placing a piece of wood over the end of the axle, and hitting it with a decent sized hammer?
