4th gear grinds sometimes
Old Mar 12, 2008 | 10:05 AM
EVIL_EVO_VIII's Avatar
Unhappy 4th gear grinds sometimes
Well after 28xxxk miles, my 4th gear grinds occasionally if i shift real fast past 6500 rpms.. Its not a bad grind but noticeable. This is the first time out of my 3 evos that ive ever had any tranny problems.. My clutch is also slipping badly at 15psi of boost.. Ive been meaning to make an appointment for a new clutch with TTP but work and moving took up all my time.. Do you guys think that the worn out clutch is causing the slight grind? Car has been to the track a total of 3-4 times
Old Mar 12, 2008 | 10:08 AM
TeStUdO's Avatar
j14mp's Avatar
I have the same issue. People telll me it's my syncros. Mine grinds going into 4th and 5th at WOT. My car has 38 k on it. I rarely ever do it. I'm going to try to get that BLOX (I think thats what it's called) transmission mount from speedelement and see if that helps any. Maybe you should give that a shot too.
Old Mar 12, 2008 | 10:10 AM
jmartinez1170's Avatar
Man just send it to shep and call it a day. You wont be able to go to the dealer with your mods been there done that.
PS: my car will be done by the end of may. Ill be rocking a GT40 for the summer and winter then ill put the 42 on.
Old Mar 12, 2008 | 10:12 AM
Originally Posted by TeStUdO
The worn out clutch plus the notoriously weak 4th gear in the 6 speed tranny is probably reeking havoc on your synchros.
I have a 5 spd
Old Mar 12, 2008 | 10:14 AM
TeStUdO's Avatar
Originally Posted by EVIL_EVO_VIII
I have a 5 spd
My bad, I thought you had an MR for some reason. It's still your synchros.
Old Mar 12, 2008 | 10:16 AM
whitersevo's Avatar
adjust your clutch pedal, just a little bit... That should do it..
Old Mar 12, 2008 | 10:25 AM
TeStUdO's Avatar
With a slipping clutch, that probably won't help.
Old Mar 12, 2008 | 10:33 AM
Im having the clutch replaced soon and ill have Scott put some penzoil syncromesh to see if that helps
Old Mar 12, 2008 | 10:52 AM
evo9 ate u's Avatar
wat tranny fluids are you using?
Old Mar 12, 2008 | 10:59 AM
OEM
Old Mar 12, 2008 | 03:30 PM
TTP Engineering's Avatar
The more you drag out that clutch replacement, the more damage you are doing to your transmission. The flywheel is likely warped and the high spots are likely hanging up on the disc.
Old Mar 12, 2008 | 04:07 PM
I know Scott. You will hear from me this week for the appointment
Old Mar 12, 2008 | 05:18 PM
Viciouslord's Avatar
Miguel... IMO... i wouldnt put that crap Penzoil Syncromesh in the tranny. it has the consistency of water, offers no protection what so ever. yes i did use it for a while with no problems but when i saw Ryan drain out the tranny, it looked like water. i said never again.
Shep recommends Mt90, he builds these things daily, he should know more then anyone.
i will say this though, Mt90 when cold feels a little notchy but after it warms up the tranny shifts like BUTTA!
Old Mar 12, 2008 | 05:21 PM
Ph3n1x's Avatar
^ Ive been using synchromesh for 50k miles and it has given me no issues. Has actually solved a 5th gear grind issue. If it ain't broke why try to fix it.
