egr elimination
20grockit, i just put a new intake manifold on, did your car run rough or anything when you turned the EGR off? also did you get a EVAP code at all? thanks for any help
yes you can sorry i was at car trying to get some results but no luck still. Anyway if you do it right you shouldnt get any lights for anything.
I disabled my rear o2, egr, and evap. All with no problems. I use scan tech also and the rear o2 comes up N/A which means you'll still pass emissions. And the egr and evap are disabled in it but i believe with them disabled that causes a problem for emissions for some.
yea i need to pass emissions. so the egr disabled wont pass and the car will fail for emissions?
