egr elimination
Old Mar 16, 2008 | 06:52 AM
20Grockit's Avatar
egr elimination
hey guys im so sick and tired of having egr problems its ridiculous. is there anyway to eliminate the egr system without causing a cel. im still on stock ecu as well. i am running ecuflash and evoscan. im just tired of blowing off hoses and now that i do have the hose situation taken care of the damn control solenoid is busted. dont ask how b/c my guess is as good as yours. help me out.
Old Mar 16, 2008 | 06:58 AM
Evo8Emperor's Avatar
You can turn it off in the ecu by using the perephery patch.
Old Mar 16, 2008 | 06:59 AM
20Grockit's Avatar
ok. where can i find the patch???
Old Mar 16, 2008 | 07:04 AM
Its on aktive matrix do you have a name on there ? If not ill see if i can find it neway.
Old Mar 16, 2008 | 07:12 AM
20Grockit's Avatar
no i dont have one on there i used to but cant remember the name or p-word for it. see if you can find someone with that patch for me man and it will greatly be appreciated.
Old Mar 16, 2008 | 07:18 AM
If you want to disable EVAP set ECU Perephery2 = 0xCFDF
If you want to disable EGR set ECU Perephery2 = 0xEDDF
If you want to disable EVAP and EGR set ECU Perephery2 = 0xCDDF
Obviously the factory default for ECU Perephery2 = 0xEFDF
Old Mar 16, 2008 | 07:19 AM
working on the other part you need to paste. I actually think its in ecu flash
Old Mar 16, 2008 | 07:23 AM
here it is just pulled it from my xml file i dont feel like searching.
<table name="ECU_PEREPHERY" category="Misc" address="faa" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY1" category="Misc" address="fba" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY2" category="Misc" address="fca" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY3" category="Misc" address="fda" type="1D" level="4" scaling="Hex16"/>
just paste any where after evo 7 base
Old Mar 16, 2008 | 07:24 AM
20Grockit's Avatar
thanks man thats awesome. bump for you. i know im probably buggin you man but where exactly do i need to paste this?? in my rom definition such as 96940011.xml?
Old Mar 16, 2008 | 07:25 AM
20Grockit's Avatar
ok thanks man thats great. can i just remove all the hoses and plug up the holes?? i have to keep the solenoid plugged in correct??
Old Mar 16, 2008 | 07:27 AM
Yah sorry no problem im always asking for help glad i can help sum1 out.
Yah what ever rom definition your ecu is go into Open Ecu where ever you DL Ecu Flash open the xml up in word pad and paste that above anywhere after evo 7 base but before the last <ROM>. And make sure word wrap isnt selected.
Also save a back up just incase before you change yours.
Old Mar 16, 2008 | 07:28 AM
yah because its on your manifold. theres holes underneath it unless you make a plate for it.
Old Mar 16, 2008 | 07:29 AM
I run an aftermarket manifold so i was searching for a lot of things. Also that perephery patch controls everything dude. You can turn off anything you want.
o2 sensors. a/c anything. Theres a excel document in ecu flash called umm perephery something that gives you all the other codes.
Old Mar 16, 2008 | 07:30 AM
20Grockit's Avatar
ok thanks man. huge bump for your quick response.
Old Mar 16, 2008 | 07:35 AM
Let me know how it goes. Should have no problems. Its easy.
