Meth Question
Old Mar 16, 2008 | 03:00 PM
1NastyMR's Avatar
Meth Question
What is a Safe Meth/Water Ratio to use or is 100% meth Safe? Also how much can I boost using meth?
Old Mar 16, 2008 | 03:28 PM
evilempire76's Avatar
This should probably be posted water/alcohol injection section of the forum.
Yes you can run 100% meth or mix for different ratios. It just depends on what you are trying to accomplish using the injection. More water in the mixture will cool the intake charge better than just running straight meth. Mixes vary from 80/20 meth/water, to 50/50 meth/water. Running straight meth will be used to basically up the octane of your fuel so you can run higher boost and more timing. If you are on a stock turbo then should be able to easily max out the boost of the stocker if you are spraying enough meth.
Old Mar 16, 2008 | 03:53 PM
1NastyMR's Avatar
I wanna run about 28psi and make about 400 at the wheels or close to it with my full bolt ons. Will I need larger injectors to run meth?
Old Mar 16, 2008 | 04:45 PM
No. Meth will make up part of your fuel, so you will not need larger injectors.
Old Mar 16, 2008 | 06:22 PM
t51splbb's Avatar
That would depend on your current injector duty cycle. If you're running cams along with the typical bolt on mods you may need to go to bigger injectors. Log the car to determine whether you need to or not.
Old Mar 16, 2008 | 06:45 PM
IXmr321's Avatar
I run 100% meth and 30-33psi, depending on the weather
hktrigguy
Oct 31, 2016 07:50 AM
CopartJohn
E85 / Ethanol
Aug 11, 2016 10:25 AM
PcK EvO
46
Aug 15, 2013 08:39 AM
1mbrews8
Nov 17, 2007 02:54 PM
DS-03evo
32
Feb 17, 2007 09:09 PM
