Gears Hard to Engange on Fresh Rebuild
So, I got my car back from the dealership today after a fresh rebuild (courtesy of Mitsubishi's MR transmission TSB). Anyway, it is extremely difficult to engage any of the gears at low speeds (e.g. while stopped at a light or driving through a parking lot). I mean, I am a big guy and I have to put some serious strength into it. What is odd is that it becomes easier to shift higher RPM's.
My first thought is clutch and that it needs adjustment. Even with my foot all the way to the floor when I change gears the car tends to lurch as I engage each gear, meaning that the clutch is not fully disengaged (or engaged)? Does this sound like it could be solved by a simple clutch adjustment or does the transmission simply need to be "broken" in?
Thoughts?
Thoughts?
If it were the clutch, would it still be hard to engage gears while the car is turned off and parked?
I've NEVER felt a transmission like this before, they have rebuilt this transmission before and it shifted like BUTTER when I got it back which leads me to believe there is something SERIOUSLY wrong with this one.
I will give it the 500 miles and see how it goes.
Do not give it 500 miles! Adjust the clutch and make sure to bleed the clutch line too. You should never have to put much force behind it to get it into gear. I'd take it back at the very least if you don't feel comfortable doing it yourself. If you are forcing it you could really screw up the tranny , if you haven't already.
I had the same exact same thought of causing MORE problems driving it. They had my car for over a month, I was itching to drive it again, otherwise I would have left it there for them to fix it.
edit: just saw your post above about the car being off... you likely have an internal transmission problem
Interesting, it doesn't make any sense to me. A brand new transmission from the factory shifts perfectly, the last time they rebuilt it shifted fine, why all of a sudden so I have to slam it to get it into place?
I've had it a couple of times where it refuses to get into gear, missed shifts, syncro grinding, it's embarrassing! Like I am just learning how to drive a stick!!
