Gears Hard to Engange on Fresh Rebuild
Old Mar 20, 2008 | 12:17 PM
4ringturncoat's Avatar
Sounds more like the shifter cables are not adjusted properly. To find out if it is the clutch adjustment put the car on jackstands and start her, if the wheels turn with the clutch fully depressed adjust it till they stop. If that is not it then I would get it back to the dealership and have them check the cables and shifter base are ok. Since it it doing it with the engine off I would lean more toward miss adjusted cables or a bad rebuild.
Old Mar 20, 2008 | 03:54 PM
CULVIIIER's Avatar
Originally Posted by Last4G63
Interesting, it doesn't make any sense to me. A brand new transmission from the factory shifts perfectly, the last time they rebuilt it shifted fine, why all of a sudden so I have to slam it to get it into place?
I've had it a couple of times where it refuses to get into gear, missed shifts, syncro grinding, it's embarrassing! Like I am just learning how to drive a stick!!
Did you put a new clutch in? Sounds like gear lock out.
Old Mar 20, 2008 | 04:47 PM
Gear lockout happens at high rpms were the clutch disk can't be slowed by the sychros soon enought to make the shift, not by daily driving and with the engine off.
Every time you make shift forcing the gears you are wearing the cones off the sychros, get her back to the stealership and have them check it out. Ask the service manager to drive it WHILE you go with him, see what he/she thinks.
Old Mar 20, 2008 | 06:14 PM
whitey4d's Avatar
I would pop the cables off the levers and see if its hard to egage then. That will eliminate the cables and bracket being bent.
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Kreeker
Aug 3, 2014 01:17 PM
ChefJMB
Jul 13, 2013 10:13 AM
I4UnderPressure
Dec 10, 2011 08:30 AM
Thegame
Jul 18, 2007 05:25 PM
