HELP!!! broken turbine tip
Old Mar 18, 2008 | 04:07 PM
Pure Playaer's Avatar
green ftw
Old Mar 18, 2008 | 05:22 PM
AndyBandy's Avatar
Originally Posted by 94AWDcoupe
I have experience with stuff like this. Both compressor and turbine size mishaps. that damage is small. I would use small die grinder with small cutoff wheel. remove an equal amount from the opposing blade only. it will work fine and not cause any performance loss whatsoever.
so by doing the opposing blade only it should keep the overall balance? I was hoping that the damage was considered small, but this topic isnt covered too often. i'm just trying to fix it while its open if it will definitely be an issue.
Old Mar 18, 2008 | 05:25 PM
evohang's Avatar
wow just with that littl damage the turbo could go bad? I learned something today. Considering i would very thought of that or know of. Sorry newbie here.
Old Mar 18, 2008 | 05:28 PM
TTP Engineering's Avatar
Jerry knows his stuff. Be careful not to screw any others up.
Old Mar 18, 2008 | 05:36 PM
AndyBandy's Avatar
thanks for the backing of his reputation, its hard to take some advice given unless someone has first hand experience with it.
again...thanks TTP!!!
Old Mar 18, 2008 | 05:44 PM
94AWDcoupe's Avatar
Yes the idea is to keep the blade in balance. I have done it with chips three times that size. Turbos provided years of service and still tight.
Old Mar 18, 2008 | 06:11 PM
AndyBandy's Avatar
thanks a ton for the support!! I'll do that tomorrow, i'm just going to find a small enough grinder. all i have is the industrial / commercial 5" wheel which wont work
Old Mar 18, 2008 | 06:25 PM
VRSF Tiago's Avatar
You should really have it balanced after you clip the opposing turbine wheel. It will be unbalanced, but the more balanced it is, the less problems you'll have with the seals & shaft play in the future.
Old Mar 18, 2008 | 06:36 PM
AndyBandy's Avatar
by balanced you mean actually taken off of the turbo and balanced? or just clipping the other side to try to balance it as best i can while its on the car?
Old Mar 18, 2008 | 07:03 PM
CO_VR4's Avatar
The first poster who suggested clipping was not making reference to you doing it yourself. Clipping a turbo wheel is a common practice, but it's done with equipment that clips all the vanes exactly the same amount. It permits the extra back pressure to go by the wheel with less restriction in the high end of the RPM range. It just happens to be in the same area as your lost part of the vane, which part would be removed anyway. Your choice, I just wanted to clarify for those who may not know that information...
Old Mar 19, 2008 | 03:57 AM
AndyBandy's Avatar
Originally Posted by mplspilot
Don't have to drain oil.
Remove intake, downpipe, LICP, undo water and oil lines, undo manifold and pull it out.
by "undo water and oil lines" what does that exactly mean? i understand that the lines feed the turbo, but arent they always filled? If i take it off wont it leak everywhere? ..or just whats in the line itself?
sorry for the newb question, i just dont want a surprise
Old Mar 19, 2008 | 04:51 AM
CO_VR4's Avatar
The oil drains down the oil drain pipe, and there's just a small amount in the turbo when the car is not running. You can catch it in a 12 oz cup.
Similar for the antifreeze. Keep the feed line pointing up and you'll lose even less.
Old Mar 19, 2008 | 05:02 AM
deadbeatrec's Avatar
Originally Posted by taenaive
I would try to clip the equal size to all the fins to balance. you would get a slow spooling turbo but it might give you better high end in theory.
aaaaaahahahahhaa
this is a joke right? by the way, how do u sugest he do this, nail clipers? haha
Old Mar 19, 2008 | 10:11 AM
cpoevo's Avatar
I would not do this if I was you. Turbos are balanced at high speeds and operate at high speeds. You are trying to balance something yourself that will spin greater than 100,000 RPM.
Old Mar 19, 2008 | 05:04 PM
AndyBandy's Avatar
well there is always tolerance in balancing, i know it wont be 100% perfect, but i've got to try something.
