Q for Beatrush diff bushings users
Old Mar 18, 2008 | 11:25 PM
cal1mr's Avatar
I'm in the middle of installing these at the moment and ran into a possible fitment issue that I'm unsure about. Are the polyurethane ring bushings supposed to float around loosely when the bolts are tightened? Looking at the other side that still has the stock setup, I can see that there might be a reason for this clearance but if someone could just verify one way or the other I would appreciate it.
Old Mar 19, 2008 | 01:51 AM
James@DSR's Avatar
You might have ordered the ones that are for Evos equipped with AYC. USDM Evos do not have AYC therefore have a different set of bushings made by beatrush. I specified that when I ordered mine from them and mine fit snug after I torqued the bolts down. Im actually 100% thats your problem are you mightve stripped the bolts real bad that they wont go in all the way and theres still play in the bushings. Just search here on EVOM I remember a thread about these...
James
Old Mar 19, 2008 | 05:58 AM
gamebred26's Avatar
def should not be loose and or floating
Old Apr 25, 2008 | 08:13 AM
Carloverx's Avatar
bump. can someone give me an idea on install time? Some say u need to drop the diff while others say it takes 10 mins with an impact gun?? Thanks
Old Apr 25, 2008 | 08:26 AM
gamebred26's Avatar
cordless impact gun..takes 15 minutes
back out the bolts but not all the way so the diff does not drop...
then do one side...take one side all the way out...take old bushings off put new ones on...then start it back in...but don't tighten all the way up..just a few threads to hold the diff up...
do the other side....take it all the way out...replace bushings...same deal...
then tighthen both up...
you're done
StormTroperX
Jan 26, 2013 11:23 PM
escodotcarter
Apr 25, 2011 02:14 PM
R/TErnie
30
Dec 22, 2010 12:55 PM
Smogrunner
May 22, 2006 04:31 AM
Grog
Feb 16, 2005 11:52 AM
