Boost Leak
Old Mar 19, 2008 | 01:20 PM
SuPeRNeT's Avatar
Boost Leak
Well day before yesterday, I was rockin out a boost test and I could here massive air leakage.. but was having a hell of a time finding where it was coming from. Found 1 leak at my UICP coupling, fixed. But still leaking really bad at the Intake manifold, so thought it was Throttle body, nope. Got under the car and looked at the back of the intake manifold and saw 2 hoses disconnected,WTF. Look a little closer and saw a solenoid similar to the boost unit with the nipples torn off !! Unplugged the hose that it was connected to and Plugged all 3 hoses and Vola boost leaks taken care off for the most part.. But i can still here air in my down pipe??? I'm guessing it coming out the Ex Mani and out the pipe because of a valve still open, does this sound right??
Well any ways it's some of the ERG stuff thats broke so i disabled it via ECU heres a pic of it..
Old Mar 19, 2008 | 01:59 PM
Evoryder's Avatar
did you reconnect the hose to the valve or just plugged them with something?
Old Mar 19, 2008 | 02:08 PM
SuPeRNeT's Avatar
The nipples on the valve had been broke off.. So i unplugged the 3rd hose on the bottom of the valve and then Caped off all 3 hoses.
Old Mar 19, 2008 | 02:22 PM
Evoryder's Avatar
broke off? wow. Those hoses are a pain...i zip tied them last time. Are you holding boost during the test? And where are you addding the air to? TB or Turbo.
Old Mar 19, 2008 | 02:29 PM
Exciting News's Avatar
The open valve to downpipe issue sounds about right. Can you post or PM me the original version of that pic?
Old Mar 19, 2008 | 02:57 PM
SuPeRNeT's Avatar
At the turbo..
Old Mar 19, 2008 | 03:01 PM
SuPeRNeT's Avatar
Sure here you go.
Old Mar 19, 2008 | 03:55 PM
Evoryder's Avatar
just doing a boost leak test and the found the freakin 3rd hose is off..that damn valve + high boost = annoying.
Old Mar 19, 2008 | 04:59 PM
SuPeRNeT's Avatar
Pull it or clamp it. If you pull it disable ur egr.. Egr FTL!!
Old Mar 19, 2008 | 05:00 PM
SuPeRNeT's Avatar
It holds boost for a sec but then leaks out the Down pipe.. I hope thats normal...
Old Mar 19, 2008 | 05:04 PM
OzKing50's Avatar
check your intercooler aswell
Old Mar 19, 2008 | 05:05 PM
SuPeRNeT's Avatar
Did that all ready
