Unofficial HKS EVC VI thread.
Old Dec 5, 2008 | 08:44 PM
  #61
ROGERV's Avatar
Originally Posted by ROGERV
SWOLN, where did you tap the ecu to get the rpm/throttle signal. is it pin 84 and 86 ??
http://www.roadraceengineering.com/e...-ecuwiring.htm
Just want to make sure I have mine installed right.
Thanks !!
Okay I figuered it out. You use pin#58 for Tach signal and pin# 84 for throttle signal. (do not use pin#86 for tach signal)
Old Dec 6, 2008 | 09:20 AM
  #62
SIKEVO9's Avatar
Originally Posted by Evo Tengoku
FUN 6 is rpm x throttle position?
yes, i would like to set this up. any info is appreciated. Thanks
Old Dec 6, 2008 | 09:58 AM
  #63
SWOLN's Avatar
Glad you got it. Did you set the throttle voltage on it ?
Old Dec 6, 2008 | 09:59 AM
  #64
SWOLN's Avatar
I thought FUN 6 was Speed and Throttle, and FUN 5 was RPM and Throttle
Old Dec 8, 2008 | 11:20 AM
  #65
ROGERV's Avatar
Yes I did.
How did u set up your rpm map?
It says in the manual to not go more than 100rpm +/- ? Just wondering if anybody tried something diffrent like 200rpm or 300rpm.
Old Dec 8, 2008 | 07:07 PM
  #66
SWOLN's Avatar
It specifies that so the psi doesn't fluctuate to much. It could become difficult to tune with it bouncing all around. When I set my map up I looked at where the boost started to fall off, from there, to my set redline I just spaced out the rpms evenly. 2-300 seems okay.
Old Dec 9, 2008 | 05:03 AM
  #67
Evo Tengoku's Avatar
We got it to peak 26psi and hold pretty good. By redline it dropped to 24psi. Stock turbo can only do so much.
Old Dec 9, 2008 | 07:27 AM
  #68
SWOLN's Avatar
O.T. hmmm, yeah a little porting could help on the turbo, exhaust mannifold, 02 housing to lower back presure...
Old Dec 9, 2008 | 07:39 AM
  #69
exhaust manifold is ported and o2 is an ebay/megan. but im happy with my setup for now. we did 28 pulls on the dyno. a third of those were to tune the EVC 6.
Old Jan 16, 2009 | 05:56 AM
  #70
theshadow's Avatar
Can you use the EVC 6 to set boost by gear?
Old Jan 16, 2009 | 06:40 AM
  #71
SWOLN's Avatar
I suppose you could use the speed function, I think it's 6, to simulate the boost by gear.
Old Jan 16, 2009 | 08:10 AM
  #72
monkey_187's Avatar
Will I have to reprogram my EVC6 if the battery was disconnected? I am deployed and found out my relatives diconnected the battery and would only connect it when they started it up.
Old Jan 16, 2009 | 09:30 AM
  #73
ROGERV's Avatar
No, you will not have to reprogram. It still saves your info even if batt. is disconnected.
Old Jan 16, 2009 | 09:44 AM
  #74
Tribal's Avatar
damn thank god for this thread....I have not be able to get my EVC VI working the way I want it to work for 2 reasons...im running a big turbo and it reads in KPA.
Old Jan 16, 2009 | 09:49 AM
  #75
SpoolnupTuning's Avatar
We are currently holding and sometimes creeping above 30psi on the red! I believe with the evc6 we could hold 33 to 34 psi with the red! The green is another story, we were only able to hold 26psi by 7k with a spike of 30psi! The easywriter software is alot easier to use, but works the same. I would recommend using the software if you want too log your boost and get it closer!! Later today i will be doing some logs and will post them up. It will be on a evo red.
