8 vs 9 O2 housing differences ?
I am putting a used 9 turbo on my 05 mr 8 is it worth it to change to a 9 O2 housing or are they the same?
what about mani's are they different?
I am almost positive that the VIII and IX factory cast iron O2 housings are identical. An inexpensive upgrade worth 10-15 WHP is a Buschur coated O2 housing. There are several other brands of stainless O2 housings as well.
The manifold and o2 are the same, but the oil/coolant lines and compressor outlet pipe are different. Make sure all that comes with your turbo, and if you get the mani/o2, send them to Buschur to get ported/coated. When they come back, swap them on in place of your stock parts, then sell those.
Yes the porting of the manifold should be done since you'll have the turbo off anyway. Heads up on the oil & coolant lines as well as the compressor discharge tube, Warr!
