how do i log aem uego wideband to evo scan
Old Mar 30, 2008 | 03:45 PM
HaVoC RR's Avatar
i called aem up and the tech told me to get a 9 pin serial cable and use the blue wire "serial output" from the wideband to the laptop. ..i was like huh.what and how does the blue wire go into the serial cable.do i need a aem program or i can use evo scan. if i get a serial cable how do i know which hole on the other end of the cable do i tap into? im lost guys i need some help here.
Old Mar 30, 2008 | 03:54 PM
Liqquid's Avatar
https://www.evolutionm.net/forums/sh...&highlight=AEM
Old Mar 30, 2008 | 04:01 PM
HaVoC RR's Avatar
thanks liqquid..THANKS A BUNCH, i owe u a beer
i searched but didnt find that..guess im inpatient and didnt look hard enough..
Old Mar 30, 2008 | 04:10 PM
Liqquid's Avatar
No prob!
Old Mar 30, 2008 | 06:55 PM
Precision's Avatar
Agreeed, I'll be installing my UEGO next week this saves me about half an hour! Thanks!
Old Feb 17, 2011 | 06:44 PM
ch1215g's Avatar
SUSPECTED SCAMMER
is there a way to take a serial cable and a usb cable cut them and put them together?
Old Feb 18, 2011 | 04:46 AM
raasfaas's Avatar
I'm pretty sure there is but why not just get a serial>usb adapter and save yourself the hassle:
http://www.newegg.com/Product/Produc...-105-_-Product
Old Feb 18, 2011 | 06:13 AM
Creamo3's Avatar
Better yet, run the blue wire (0-5v Analog) from your AEM UEGO gauge straight to the rear O2 pin on the ECU harness. You won't need any wires to log your AFR and can simply log it thru the OBDII port w/ your ECUFLash cable. I just spliced the wire into the existing input and didn't remove the pin. If you're running a V7 Tephra rom just enable the Rear O2 simulator and you're good to go.
https://www.evolutionm.net/forums/ec...ial-cable.html
Old Feb 18, 2011 | 06:40 AM
tscompusa2's Avatar
https://www.evolutionm.net/forums/la...o-evoscan.html
Old Feb 18, 2011 | 11:52 PM
ch1215g's Avatar
SUSPECTED SCAMMER
thanks guys got it done! what about logging boost? i got a boost gauge with the ability to log it
Old Feb 19, 2011 | 11:19 AM
killerpenguin21's Avatar
probably easiest to just put in a omni 4 bar map sensor and make the changes to the rom and do it directly through the ecu like stock.
tscompusa
Nov 5, 2015 05:24 AM
mac_05evo
Mar 8, 2014 08:09 AM
rogue
Aug 6, 2009 05:00 PM
def1
Feb 16, 2009 12:33 AM
skold
Dec 6, 2007 08:52 PM
