Benefit of Factory Air Intake Duct?
Old Apr 3, 2008 | 11:54 AM
tvbf1's Avatar
I think there's a gain to it. It'll help circulate air better while driving. If you're just parked and the dyno then I see no gain.
Old Apr 3, 2008 | 11:57 AM
Pirana's Avatar
cooler air
Old Apr 3, 2008 | 12:05 PM
mplspilot's Avatar
Cold air gets under the hood through the grill opening when driving. You don't need the duct for that.
That duct routes some of that outside air blowing past the top of the cone filter towards the fender and fusebox maybe. I don't see how that can be helpful to anything.
Old Apr 3, 2008 | 12:54 PM
Jeff_Jeske's Avatar
If you have an open filter and are making let than 400whp then theres no reason to not use the stock box with drop in. Sucking in hot engine bay temps is retarded. The stock snorkle forces cool high pressure air from the nose of the car right down the filters throat. Hard to beat that unless you have a very big turbo.
Old Apr 3, 2008 | 01:14 PM
mplspilot's Avatar
Cone filter will hold more boost up top, whether you make 400whp or less. So it is beneficial to most people.
Old Apr 3, 2008 | 01:18 PM
tkklemann's Avatar
No, get ridof it, its benefit is less that taking out the rubber piece that seal off the top of the headlight to the underside of the hood. I have 30+ datalogs to show the snorkel does less than removing the rubber piece. On my specific car, I see AIT's only 7* above ambient in a steady state cruise.
Remove it along with the rubber piece, and you are good to go..
Old Oct 24, 2021 | 03:51 PM
Evo_Jay's Avatar
https://www.evolutionm.net/forums/ev...ed-tuning.html
Terton01
Mar 26, 2012 02:06 PM
timereaper
Canadian
Nov 19, 2011 07:53 PM
Bear.914
Apr 18, 2011 09:23 PM
Blue_Warrior
Apr 7, 2011 01:31 PM
kabome
Toronto Lancer Club
May 31, 2010 06:32 AM
