where to buy .82 housing?
Old Apr 3, 2008 | 06:52 PM
Dapper Dan's Avatar
Im trying to find a 4 bolt .82 turbine housing for my gt35r, does anyone have a link to where i can buy one? Cheaper the better lol.
thanks in advance...
Old Apr 3, 2008 | 06:59 PM
2theMAX's Avatar
www.Forcedperformance.com
Old Apr 3, 2008 | 07:55 PM
David Buschur's Avatar
I am pretty sure I have a new one at the shop with the 3" 4 bolt outlet. Give us a call if you are interested.
Old Apr 3, 2008 | 08:03 PM
Dapper Dan's Avatar
That one has the long neck right? do you happen to have any with the shorter neck that are 2.5?
new or used
Old Apr 3, 2008 | 08:09 PM
ExViTermini's Avatar
new or used
The "long neck" and 3" would suggest that it is a true GT housing from Garret. The 2.5" would be the standard style t31 housing.
Correct me if I am wrong?
Old Apr 3, 2008 | 08:12 PM
I may have the 2.5" too, you'll have to give us a ring and see. Obviously at 11 pm I am not at the shop
Old Apr 3, 2008 | 10:10 PM
riceball777's Avatar
both the gt 4 bolt and the t31 2.5 bolt housing for the gt35r can be had at atpturbo.com. they are about $300 each. only use the t31 2.5" 4 bolt housing for clearanse issues. the gt 3 inch 4 bolt and the 3 inch vband housings have a longer neck and make it harrer to keep ac. but if your geting the longer neck you might as well get the v band one like mine
long neck type turbine housing. HTAgt3582r with 3" vband .82ar t3 housing
tight clearance short neck housing. HTAgt3582r with 3" vband .78ar t3 twin scroll housing
Old Apr 5, 2008 | 06:12 PM
crazyitr's Avatar
Vband makes it a lot easier to remove turbo/downpipe when that situation arises. It also allow for the exhaust housing to flow more air. Less backpressure= better spool and more HP
Old Apr 5, 2008 | 06:21 PM
Dapper Dan's Avatar
yeah i needed the short neck one because with my new mani i would have to get rid of the ac or have an very sharp turb right out of the turbo.
but buschur took care of me, hopefully it will be here next week
Old Apr 8, 2008 | 12:49 AM
then just get the standard t31 2.5 inch 4 bolt .82 t3 housing for the gt3582r
they can be ordered at www.atpturbo.com
