Evo VIII vs Evo IX : tuning potential
Hi guys,
I'd like to ask your opinions about these 2 type of engines.
Which would react better to heavy mods/high horsepower ? (evo 8 or evo 9 engine)
I'm thinking of getting an Evo IX but am afraid there's less things I can do with it.
Do help me on this, I tried searching but all that came out was people comparing 8 vs 9 turbos.
Thanks guys.
Thanks guys.
unless your building an 800 hp drag car the ix beats 8's hands down, if you plan on going over that then just get an 8 because all of the 9's perks are pretty much not beneficial
There's a lot about the 9 that makes it better than the 8 besides MIVEC...
the stock cams are very well suited to the engine
the timing belt is stronger
the head gasket is better
the turbo has more potential
the ECU has a much larger & more capable ROM
the stock BOV is stronger
the intake manifold has an IAT location
IX responds very well to mods much better than the VIII. Like said above, anything over a certain limit then it's not as much of a concern. You can accomplish 400-500 whp cheaper with an IX compared to an VIII.
The Evo IX definately has it's perks out of the box. But, if your going for that much power (800whp) I think the difference between the VIII and the IX isn't that important. Like the guy stated earlier, the IX has some better stuff from the factory, but if your shooting for the moon your changing that stuff out anyways. Good luck!
You need to define what you mean by "high horsepower", and you'll need to figure out what kind of fuel you'll be running. IMO, the IX block is hands-down better, because of all the above mentioned reasons and because it cools better (redesigned cooling passages in the block and head). Unless you're shooting for a 42R powered drag car, I'd say go with the IX.
l8r)
l8r)
I think most people will benefit more with an IX. I dont think you need to be looking for 800hp before they even out though. There are WAY more 500whp evo8s than there are evo9s on 93 oct only.
Hi guys,
Thanks guys.
Thanks guys.
#1- You drive an EVO VIII. It has 62,000 miles and some bolt ons and put down 327whp & 322wtq. Your interested in a newer car and find a EVO IX w/ 28,000 miles and bone stock. You plan to add a few bolt ons, and possibly a 20g in the further out future. You like the look, drive, and etc., of the IX better and you realize just a few bolt ons and tune will put you right back at the power levels of your VIII. In this case get a IX for sure.
#2- You drive an EVO VIII. It has 48,000 miles and some bolt ons and put down 327whp & 322wtq. Your interested in a newer car and find a EVO IX w/ 28,000 miles bone stock. Your plans are to go big turbo, built engine, and all the supporting mods. Your thinking maybe going with a 35R turbo or bigger and hope to put down 600whp+ and daily drive. In this case there really isn't a huge difference between the two, and in my opinion it would be better to just stick w/ your VIII and go from there.
Of course if your just tired of your VIII and want something newer, that is fine . But in all honesty there isn't gigantic differences between the VIII and IX, not like the IX to the X.
There is an interesting article on this site about using S1 cams from GSC in the project EVO. Those cams look really nice, but I was wondering if they work as well on an Evo IX, with the MIVEC variable timing? The project Evo is an Evo VIII.
^^^What does that have to with this thread? Absolutely nothing. So please stay on topic. I completely agree that if you are going for all out HP then keeping an VIII is just as effective as going to a IX. If you are just looking for lower numbers without spending a crap load of $$ then the IX is the way to go.
You have an VIII MR now? If that's the case, I would just stick with the VIII and throw on some good bolt-ons. If you were purchasing an Evo for the first time, then I would get a IX. But overall the IX has better modding capabilities and responds to tuning really well. Just weight out all of your options and compare it side by side cost wise. Just my $.02
There have been IX's running 11's on this forum with just basic bolt-ons and only the exhaust cam changed to an EVO VIII 272 Cam...
If you want to go Cosworth Cams with Springs and Retainers the sure it is worth changing both Cams on an IX coz the guys with Cosies do seem to get better results...
