Cams for a 50 trim on 93
Old Apr 4, 2008 | 03:51 PM
paintballproam's Avatar
Currently ive got a set of 264/272 cams on my 50 trim set up which made 370hp @ 20psi at DSG tuning. I was wondering if i should upgrade the cams, and if so, to what ones? How much of a power gain could i expect? obviously with a retune.
Old Apr 4, 2008 | 03:55 PM
SOEuro's Avatar
what brand do you have in there right now
Old Apr 4, 2008 | 03:56 PM
2003lancerevo8's Avatar
I used hks272's on both and achieved 500 whp with the mods in my sig. Are you on a flash or stand alone?
Old Apr 4, 2008 | 04:01 PM
you could go GSC1's which are the cams I was going to switch to, seem to provide the most power of the cams available that I have read so far.
Ph3n1x's Avatar
I think the combo is sufficient for the time being. However a 272 intake cam would have been better. Your best bet is to see how it carries you on the dyno.
Old Apr 4, 2008 | 04:10 PM
Cirrusly Evolvd's Avatar
I'd definitely go with full 272's or S1's. I had 272's on my car (see mods below) and made good power. Stepped up to the S2's (planned on bigger turbo swap) and they provide high RPM punch but are a bit too aggressive for daily driving IMHO.
Old Apr 4, 2008 | 04:25 PM
Im 99% sure they are HKS cams. I made 370hp on them.
I am on a flash, the car is tuned by Matt at DSG (dent sport garage in norwood mass)
If i were to change cams, what do you think i would make for power gains?
Old Apr 4, 2008 | 05:07 PM
Spoolin18's Avatar
I currently run Brian Crower 272's on my Peakboost 35R setup, and they made very good power. If your going to be daily driving this car, I would stick with a nice set of 272's..just my input, take it as you wish!
Old Apr 4, 2008 | 06:30 PM
Bump that intake cam up to a 272 and you should be golden
Old Apr 5, 2008 | 06:59 AM
Ludikraut's Avatar
I run HKS 280 cams (+2/0) on my 50 trim setup and I am very happy with how they performed over the HKS 272s that I used to run. I lost a little bit of spoolup (~100RPM) with the 280s, but gained power on the topend. I'll see if I can dig up a dyno chart to show the difference... Having said that, I am starting to look for a set of cams that will improve on the 280s. I have a built valvetrain, so there should be more options out there for me.
l8r)
Old Apr 5, 2008 | 09:57 AM
SickSilverNLow's Avatar
I had HKS 272s on my 57trim.....its was great.
Old Apr 5, 2008 | 11:21 AM
sparky's Avatar
Curious as to what boost level, whether 93 + Meth amd on what dyno.
Old Apr 5, 2008 | 11:27 AM
05-EVO-GSR's Avatar
Change your intake cam to a 272.
Old Apr 5, 2008 | 03:34 PM
IEXCELR8's Avatar
Why only 20 psi? Go with the 272 intake cam as mentioned. Do you want more power down low or up top? If up top go 280's.
Old Apr 5, 2008 | 05:27 PM
Randy's Avatar
272 HKS
My car made 415whp on pump gas @ 23 psi 2.0L
With the stroker 2.3 I made 432 but with 428 tq
Cyrax91
11
Jun 12, 2015 06:38 AM
CBRD
25
May 1, 2008 05:12 AM
LIL EVOL
Nov 29, 2007 03:51 PM
MR 600
Automotosports - Illinois
Nov 13, 2006 01:18 PM
superflyevo
24
Jun 26, 2006 06:09 PM
