cam question?
Old Apr 4, 2008 | 05:22 PM
ranz's Avatar
cam question?
i want to get cams for my 03 evo8, and i saw the gsc 272 intake/ 264 exhaust combination and didnt get whats the pros and cons of having that combination? so can anyone help plz!
plus, do i need to change the springs b4 installing the 272?
10x !
Old Apr 4, 2008 | 05:43 PM
recompile's Avatar
A shorter duration cam might be better suited to a pump gas stock turbo that doesn't need the extra flow, but 272 isn't very long to begin with, so I'd consider the 264 rather tame.
You don't need springs/retainers, but if you get high lift cams (11.0mm or more) you should probably consider them, especially if you want to rev to 8k on a regular basis
Old Apr 4, 2008 | 11:34 PM
ranz's Avatar
am not planing to rev as high as 8k!
and as i believe the 272 has lift 10.8 !
but y this combination? y not 268 ex/272 in ?
Old Apr 5, 2008 | 12:14 AM
hanahawaiian's Avatar
safe bet for put springs n retainer kit on cams.. so u wont blew values someday...
Old Apr 5, 2008 | 12:21 AM
Wicked E's Avatar
Cosworth 272's are 11.0 lift
Crowers 272's are 10.5 lift
Old Apr 5, 2008 | 02:39 PM
ranz's Avatar
i think the gsc 272 are 10.8 lift!
having a 264 cam on the exhaust wat benefits i get over a larger cams! is it done for a certain setup?
SrBlacksheep
13
Dec 1, 2013 09:09 PM
Evil Evolution
Oct 6, 2009 03:16 PM
Wangracing
48
Nov 15, 2007 04:11 PM
phatman2600
May 14, 2006 06:27 PM
idriveawhiteevo
Feb 3, 2005 11:49 AM
